Good Ladder For 18 Ft High Ceiling Reach? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 02:29 PM   #1
Rewards Points: 640
Good ladder for 18 ft high ceiling reach?
My entry way is 2 stories high and I need to do some finishing work at the top (crown molding mostly, and be able to get to a chandiler thats in a vaulted part at a 8/12 pitch) any recommendations on good ladders? Should I go with an extension ladder or a multi purpouse one (one that folds into different shapes) not sure if multi ones go that high though when straight? Also I need to reach to the ceiling.. should I get a 20ft max one or smaller? the ceiling I think is 18ft up from the floor... any suggestions? I'm not sure what to buy and my budget isn't too high for this... can't go above $200 probably...
BlueBSH is offline   Reply With Quote
Old 02-04-2010, 02:55 PM   #2
remodeling pro
Seems like a 14' step ladder. This should allow you to stay on the second rung from the top, which is the highest safe working rung, and still reach the chandelier and 18' peak, but you will be reaching up. An extension ladder will not have anything to safely lean on at the peak for chandelier work. Before buying, check this using your own comfortable reach. You'll be pretty tight on the price, as big step ladders get fairly pricey, at least anything sturdy enough to be safe.
troubleseeker is offline   Reply With Quote
Old 02-04-2010, 03:00 PM   #3
Rewards Points: 640
I need to safely reach the ceiling box for the chandiler, would this still work? seems a little short or am I not looking at this right
Old 02-04-2010, 05:21 PM   #4
Rewards Points: 5,336
You need a ladder like an "A" frame step ladder. An extension ladder needs to lean against something. If you look at a multipurpose unit, it will need to reach up at least 15-16' to safely work at 18'.
A simple search should tell you what's available. I think the Little Giant has a 30' unit, but don't know if it will "A" frame high enough for your needs.
Ron
Old 02-04-2010, 06:00 PM   #5
Rewards Points: 163
I use an extension ladder on my entry, I also have the soft rubber covers for the upper ends. My entry is fairly small at the floor, so I wouldn't have much room for a stepladder. Keep an eye on Craigslist for a used ladder. I got my Werner 300# 24' extension ladder for $100. Good luck!
52Caddy is offline   Reply With Quote
Old 02-04-2010, 06:10 PM   #6
Too Short? Cut it Again!
$200 is going to be the tricky part I fear and you don't want to skimp. The Little Giant system is still like $300 for the basic small unit I think? Decent stepladders have gotten more and more expensive. Something like 70 percent of the cost goes to legal fees and liability insurance by the way. Ladders remain the number one source of household injuries.
Definitely watch Craig's List or your local paper if you get one. You might think about renting or borrowing one if it is not something you will use often. Can you bribe a school or church janitor or something?
Also make sure you have enough room on the floor to expand a tall step ladder to the locking position. It will not be safe if you cannot and you may have to use an extension ladder as one poster ahead of me did. Not ideal.
Old 02-04-2010, 06:15 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
l.
that is incorrect. The ladder isn't the source of the injury. It's the dummy that does not follow safety precautions or uses it improperly
I have never seen a ladder accident that was the ladders fault when proper procedure and due regard for the condition of the ladder was followed.
Blue, how big is the floor space and how close do you need to get to the wall and how far from the wall.
step ladders, extension ladders, trestle ladders all have their uses but they also have their limitations.
Old 02-04-2010, 06:39 PM   #8
Rewards Points: 640
The chandiler is on the angled part of the ceiling, could an extension ladder rest against that? that would get me right by the light and box.... its not too far from the wall either..... the other side where i need to do finishing work there is a wall the entire way up... the entire room is 13x15 there is pretty much a place to lean against on all parts that would need worked on
Old 02-04-2010, 07:06 PM   #9
Whatever type ladder you decide on, get the best weight rating you can afford. There is a big difference in the stability, especially working from the top, between the 250# and the 300#.
Giles is offline   Reply With Quote
Old 02-04-2010, 07:13 PM   #10
nap
You talking to me?
nap's Avatar
I do not like to put extension ladders on cathedral ceilings. I have but I don't like it. As you climb the ladder, it flexes and due to the angle, it can do some spooly things.
if you can put the ladder against the wall and work backwards (another not favorite of mine), that would be your call.
Honestly, for $200, about the best thing I can suggest is renting a ladder or scaffold. A 14' ladder has a top usable step at 12' so that would get you to 18'. scaffolding would be tougher as it is generaly 5' height so 3 would make the TOP of the scaffold at 15' and you are supposed to have a side rail at (I think) 42" so that is only about 11 or 12 feet, at best. really need a bit more height and if you put the planks or platform higher, you do not have a proper height guardrail. there are remedies available for that though
I don't know if this would interest you but these are handy little things. Obviously it would be a rental situation only. I don't know if it will show up with prices but if it does, those are for an area near me. They may or may not be the same in your area:
http://www.sunbeltrentals.com/equipm...y.aspx?id=1210
Old 02-04-2010, 07:13 PM   #11
DIY staff
Rewards Points: 7,174
-----RENT A SCAFFOLD-----Why own it for a one shot job?
Much safer IMO
gregzoll (09-13-2011)
Old 02-04-2010, 07:21 PM   #12
you can rent a large step that then has a vertical section in the middle for tall ceilings. They can be a little awkward but i have used them with a body harness hooked to the rungs for stability, you may be able to rent for a long weekend with just a one day charge. I would suggest an extra set of hands for setup and as spotter/cutman
The older I get the better I was
Old 02-04-2010, 07:32 PM   #13
nap
You talking to me?
nap's Avatar
that would be a trestle ladder. functional but oh so much fun. Think of being on an extension ladder but straight up in the air.
Old 02-04-2010, 07:40 PM   #14
they are trippy
Old 02-04-2010, 07:40 PM   #15
Rewards Points: 640
I was just looking at those, I don't know what scares me more, those or an extension ladder *LOL* angle then straight up seems wierd to me
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 11:55 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
16' - 18' ceiling, how to get up there? madcitysw Off Topic 17 01-18-2008 11:25 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 11:50 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
