Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-27-2012, 10:06 PM   #1
Is This A Good Beam To Hang my Bag On?
I'm hanging my 100lb heavybag and figured this would be a good beam to hang it on. I'm a little worried though, I just don't want to cause any damage to my house (it's brand new). The beam is in my garage (obviously) right below my office. Thanks.
brownplayboy310 is offline   Reply With Quote
Old 09-28-2012, 01:09 AM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Well, it looks like you already have it there anyway so go ahead and work the bag and see if the garage falls down.
Please post a picture if it does.
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Old 09-28-2012, 08:15 AM   #3
What is above the garage? Another floor? An attic? From your picture, that beam looks too small to be any sort of structural support given the length it spans. It's also oriented in the wrong direction. Did it flex or sag any when you installed the bag?
Old 09-29-2012, 11:39 PM   #4
As your office is immediately above the place where the bag is hanging, get a 200 lb. friend to jump up and down on the office floor. If the floor doesn't collapse, you're good!
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 10:10 AM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
Cutting a beam flange devlin1k Building & Construction 17 02-13-2009 04:24 PM
replacing beam in basement bpahwa Building & Construction 4 01-12-2009 08:12 PM
recessing a beam needa Building & Construction 12 12-26-2008 11:29 AM
