#1 |
Good AM antenna ideas needed---
How can I build AM radio antenna? They seem pretty straight forward but my problem is I have alot of metal on house and large metal shop. Metal interfers with radio signals so I have my tower set up 45' from closes metal which is also about 150' of wire run to my main home theater receiver. So I think it'll need boosting, which I aready have a HD & FM antenna with built in booster and rotates. Can signal be split on tower and receiver ends and use same booster set up? Also any ideas on antenna built would be helpful.
#2 |
I will be watching your post for any ideas, because I generally only listen to AM, and have similar problems, so have tried several things over the years, with not much success. The problem that I have found is that it is a bit counter productive, because any time that I have increased reception for stations that I want to pick up, I have also increased reception for a few dozen more stations that I would not otherwise pick up, so while the clariity might go up, the clutter becomes worse.
#3 |
C Crane is suppose to be the bomb for AM radio's but, I've never used one, but according to their own words???? Have you ever tried to build a ferrite do it yourself antenna?
Last edited by jburd964; 12-09-2011 at 05:54 AM. Reason: Did someone remove link I'dthought I'd placed???? |
#4 |
Super Moderator
I changed your title--hope you don't mind---Mike----
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | jburd964 (12-09-2011) |
#5 |
Mod
Good AM antenna ideas needed---What's an antena?
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#6 |
Pro Flooring Installer
Those things that stick up on a bug's head.
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 |
#7 |
Super Moderator
Spell check doesn't work on titles----
#8 |
Recent memory, no, but now you have me thinking. Growing up in the 60's, with an uncle who was an engineer on the Saturn V program, and a mom who was involved with some of the early LanSat photograpy development, I tinkered with about every electronic device that I could get my hands on, assembled a number of Heathkits, and built a lot more toys from scratch. At one point I had a fairly elaborate ham setup, with several antennas, both for ham and regula public broadcast. Don't hold your breath, as the odds are slim that it has survived numerous cleanups and throw outs, but I will take a look in the loft in the shop, and see what I have kicking around. Maybe, just maybe, there's a long forgotten soultion there.
#9 |
If I remember correctly from my college days, the ideal antenna for a particular radio station would have a single element that would be equal to the length of one cycle of the broadcast frequency.
Without research, it my guess that an antenna for the AM broadcast would be 30/40 feet long! |
| The Following User Says Thank You to Wildie For This Useful Post: | oh'mike (12-08-2011) |
#10 |
Super Moderator
I remember that from a boyscout manual---30 to 40 feet--horizontal---sounds familiar--
#11 | |
Good AM antenna ideas needed---Quote:
http://www.1728.org/freqwave.htm A 1000 kHz frequency has a wave length of over 900 feet. I believe that an antenna length that is an even fraction of this wave length can be effective. I wonder if a ferrite core with 900 feet of wire wound around it, would make a good antenna. |
#12 |
Rusty Baker, I like. If you don't want a smartass answer, don't ask a dumbass question. I personally can't help myself if you ask ye shall receive.
#13 |
For the cost of a ferrite antenna with 900 feet of copper wire you could buy your own AM radio station.
#14 |
I wonder what would be a good length for a ferrite bar antenna? What would be negative effects of the 150' wire run to antenna? Could I use the coax that is already ran as AM signal wire as well? Would the use of the signal booster on the line be needed, I don't use it for FM are TV because FM reception is good and I get locals on satellite now. I'm going to try booster on FM and see just what I can catch, just haven't had time. Are there is any FM channels out there that carry AM talk shows.
#15 |
JOATMON
There are a lot of factors to take into account.....when it comes to antenna's and signal propogation....it really is FM (freaking magic)
To some extent, your shop is actually a good thing....I would have put the antenna on top of it....the shop acts as a ground plane for better reception....ask any CB or ham operator. AM is pretty low in the freq spectrum.....the impeadance of your coax as well as the freq response of your booster may not help you in the AM range. Personally....if you have a radio with an AM antenna connection.....a good one is one of those round hoops.....looks like an 0 about 8" tall....4" wide.....they are typically shipped with AV recievers....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Tags |
antenna, wiring ![]() |
| Display Modes | |
| Suggestions, ideas needed on building pergola | Farmer Jane | Building & Construction | 0 | 06-10-2011 11:07 AM |
| Why can't I find a good thatch rake or pine needle rake? | carl1864 | Landscaping & Lawn Care | 5 | 06-05-2011 02:01 PM |
| Backyard ideas needed | darren | Landscaping & Lawn Care | 2 | 04-27-2011 06:32 AM |
| Size of whole house fan needed | Doug Crf | General Discussion | 20 | 02-26-2011 12:29 AM |
| Front entry door repair ideas??? | 4just1don | Carpentry | 2 | 01-26-2010 08:09 AM |
