-   -   gokart help! (http://www.diychatroom.com/f2/gokart-help-2681/)
dienam3less 06-06-2006 12:07 PM
gokart help!
this is for an 8 hp motor and a small gokart. i am about 135 lbs. the motors rpm is about 2300 low and 2700 high.
ive asked about thye pully sizes b-4 but i want to check again.
will a 4 inch on the top and a 5 inch on the bottom make it so i can go fast n still have enought power to pull me plus some more?
also if i use a V belt with an extra pully that will either b pushed or pulled against the Vbelt will the belt stay were it should be n not go out of polace. and i am also plaining on having 2 small studs on either side just to help it stay in line. will this work?
redline 06-06-2006 03:12 PM
Have you thought about using a variable pulley?
Snow mobiles use them for low end torque and higher speed.
dienam3less 06-06-2006 03:16 PM
not shure on how to put one on. so not really looking into it
