go karts
Or you could do what my uncle and I did for my mini bike..We got a torque converter, they're about 200 bucks though, but at idle rpms it doesn't move, but once it reaches a certian rpm the pully's grab the belt. We're using an 8 horse kohler. I'm trying to understand your idea....so what you wanna do is make it so the further you push the throttle in, the more the pully clamps agqainst the belt? With the torque-a-verter, you can still run chains too, like the actual converter itself uses a belt, but then it has a small output sprocket, and u run the cahin from that, to the sprocket on the axle.
