Gluing Unfinished Wood To Glass - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2009, 01:09 PM   #1
Gluing unfinished wood to glass
does anyone know the best adhesive to use?
thank you!
baby12121 is offline   Reply With Quote
Old 09-27-2009, 03:12 PM   #2
Rewards Points: 346
For wood to glass I have used "Amazing Goop" and found creates a stronger bond than anything else I have tried. It does have a long cure time but you can speed the process with a little heat.
I believe it is made or sold by Eclectic Products and they do have a web site, http://www.eclecticproducts.com/ag_adhesives.htm but I get it at a local hardware store. It should not be hard to find.
Rege
RegeSullivan is offline   Reply With Quote
Old 09-27-2009, 05:37 PM   #3
thank you
Old 09-27-2009, 06:07 PM   #4
DIY staff
Rewards Points: 7,174
I've had success with silicone caulk and liquid nails.
Old 09-27-2009, 06:34 PM   #5
the Musigician
DangerMouse's Avatar
i used gorilla glue on a large mirror to solid oak frame and man, that glass ain't goin' NO-where!
i weighted the mirror down pretty good as it set though, as that stuff swells like nobody's business and could have easily lifted the glass away from the front. it swelled and filled the edges in perfectly though, and i would use it for that again any day.
DM
Old 09-27-2009, 08:35 PM   #6
Registered User
Termite's Avatar
Turkey call makers frequently glue glass to wood, and I can guarantee you that none of us will use anything besides plumbers Goop. The stuff just holds no matter what.
Old 09-28-2009, 12:02 PM   #7
Rewards Points: 346
Kctermite,
It's good to know I am not the only Goop fan out there. Do you know what the difference between the "plumbing" Amazing Goop and all the other Amazing goop products? I have bought several and they all seem to be about the same except for the color of the tube.
Rege
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
