Which Glue To Use For Vinyl/pvc Fence? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 01:56 PM   #1
rkj
Rewards Points: 79
Which glue to use for vinyl/pvc fence?
I have the following fence one which some of the stakes came out:
http://i.imgur.com/muvoVVg.jpg
What glue do I use to put them back together? It looks like there was some clear plastic type glue used previously (bottom of picture). Also, is this fence vinyl or pvc?
rkj is offline   Reply With Quote
Old 11-08-2013, 05:01 PM   #2
Rewards Points: 13,300
That's a super cheaply made PVC fence that looks like Lowes used to sell and have since been changed and is now screwed and glued.
Glue all you want it's just going to fall back off.
It needs to be screwed.
Or just replace it with a better grade fence.
woodworkbykirk (11-11-2013)
Old 11-08-2013, 05:28 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
I have used liquid nails to stick those back on. Put some blue tape around it to hold it place till the adhesive sets.
Jmayspaint is offline   Reply With Quote
Old 11-09-2013, 07:55 PM   #4
Rewards Points: 197
I have that EXACT fence on a property I own. Mine looks a lot nicer though. The previous owners installed it about 8 years ago and it still looks good. The neighbor behind has a lawn service that rips pickets off regularly. I have tried clamping with Liquid Nails and even super glue gel and they do not hold more than a couple of months. What I finally started doing is drill a 5/8" hole from behind through the "2x4" plastic. It will give you a window to put your power driver to drive 1" screws into the pickets. I found some white painted screws that work well. I'm going to rig a jig out of wood scrap soon so the whole repair will be faster. To plug the 5/8" hole you can get some plastic plugs off eBay.
Arlo is offline   Reply With Quote
Old 11-10-2013, 12:35 PM   #5
rkj
Rewards Points: 79
lol, I was thinking someone would say this.
Thanks, I noticed that the beam that the pickets are connected to has a piece of wood inside. Maybe I could just get some screws, make a hole, and screw the stake into the beam?
Liquid nails is not a bad idea. Hmmm...
Old 11-11-2013, 12:57 AM   #6
Rewards Points: 197
As I said, I used Liquid Nails Exterior and clamped it over night. About three or four months later the pickets fell off. Find a way to put screws in it. My way is nearly invisible. As someone said above they still sell the same design only the pickets are now screwed on by the manufacturer. It's a design flaw therefore I don't get mad about the lawn guys tearing mine up.
Old 11-11-2013, 08:08 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
pl premium will work/hold better than liquid nails for use with vinyl/pvc etc...
hand drive is offline   Reply With Quote
Old 11-12-2013, 08:22 PM   #8
Stairguy
Millertyme's Avatar
Rewards Points: 508
You need to use the proper glue and it will hold. Liquid nail is not what you use. You need to use a cellular glue that will fuse the PVC together, this is the one that i use
Which glue to use for vinyl/pvc fence?-image-2071756697.jpg
Millertyme is offline   Reply With Quote
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 01:33 AM
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 02:45 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-05-2010 12:44 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
