Glitter On Ceilings - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 04:12 PM   #1
Question
Glitter on Ceilings
I want to use glitter on my daughters ceiling. However, the color of glitter I want to use is just a craft glitter. Does anyone know if that is o.k. to use? Or do I have to use a ceiling glitter. Thanks
dawndweezie is offline   Reply With Quote
Old 03-02-2011, 04:46 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I used multi-colored glitter mixed into my paint for a textured wall and it went well. Very subtle little sparkles.
However, I used the same paint on a ceiling and cannot see one sparkle. I imagine I'd be able to see little sparkles a bit better if I had a lamp there.... hmmmm..... My advice to you would be roll the paint on thick, and use LARGE glitter flakes "tossed" or blown up onto the paint to be able to see them. Perhaps others here will have better ideas?
DM
Old 03-02-2011, 05:01 PM   #3
Rewards Points: 5,336
If you're going to paint the ceiling during this process, paint it first and let it dry. I'd apply the glitter to a clear poly. Mix the glitter in with the clear poly and just roll it on the ceiling. You can use a water based poly since it dries quickly and has a milder odor. Add coats as you need to get the coverage you want.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
DangerMouse (03-02-2011)
Old 03-02-2011, 06:00 PM   #4
the Musigician
Good idea!
DM
Tags
ceilings
Top coating ceilings Ron Franck Painting 4 04-01-2010 11:23 PM
Guidance for Insulating Slanted Ceilings - Cathedral Ceilings mdlorenz Roofing/Siding 17 09-02-2009 10:05 AM
Should I insulate Walls and Ceilings or not? williamj001 Building & Construction 6 07-24-2009 10:37 AM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
Texture coming off of ceilings mrswoodward General DIY Discussions 7 08-16-2007 07:42 AM
