Glass Shelf In Marble Cubby - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 03:04 PM   #1
Glass Shelf in Marble Cubby
I recently renovated by bathroom and included a marble cubby hole (18" high, 12" wide, 6" deep). I would like to spilt the space by putting in a glass divider to act as a shelf. What is the best way to mount the glass shelf into the marble? I would like to avoid any type of drilling.
Thanks ahead for the help.
tbukacek is offline   Reply With Quote
Old 05-17-2012, 07:49 PM   #2
DIY staff
Rewards Points: 7,174
Do you have a wet saw and some of the marble?
If so---make a couple of shelf cleats out of the marble and glue them in with a good epoxy--
Simple cleat--cut the marble tile to 6" or less (depth of cubby hole---
Sand both ends so you have a 1/4 round---marble is soft--ordinary wood working sand paper will do that--
Then slice off the rounded off ends with the wet saw--
dry them off--glue them in --tape to hold---a scrap of wood will hold them in position till the epoxy dries.
You may break one or two as you perfect the cutting--but this works well.
Tags
bath , glass , marble , shower
Do you have to seal marble and glass mosaic tile that is in the shower? debbieriddle Tiling, ceramics, marble 12 07-14-2012 10:32 PM
Niche, Glass shelf to back wall? wraiththe Tiling, ceramics, marble 0 12-15-2011 02:46 AM
glass shelf and medicine cabinet height amakarevic Carpentry 4 11-27-2011 07:29 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 08:10 PM
