Glass Countertops - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-03-2008, 08:05 AM   #1
Question
Glass Countertops
Does anyone know anything about glass countertops?
eleganttouch is offline   Reply With Quote
Old 06-03-2008, 09:23 AM   #2
Registered User
Termite's Avatar
What do you want to know about them?
Are you talking about countertops with broken glass as aggregate in them, ground smooth? Or are you talking about actual sheet glass counters?
Old 06-03-2008, 09:57 AM   #3
Sheet glass that we cut and fabricate ourselves. I have gotten a few numbers but so far not much luck. I need to know what type of license or certification we would need to fabricate ourselves as well as suppliers that sell sheets not pre-fabbed tops already finished.
Old 06-03-2008, 05:57 PM   #4
Advice worth 2 cents!
Rewards Points: 150
Get in touch with a PPG distributor!
_ pete
---pete
HandyPete is offline   Reply With Quote
Old 06-04-2008, 07:42 AM   #5
Registered User
Termite's Avatar
If you're a DIY-er, it isn't worth it. There is a considerable amount of large machinery that is required to perform the edge polishing and profiling that a countertop would require...The investment would run into the hundreds of thousands of dollars range.
Licenses and certifications would depend on the state/municipality that you're working in. Here, you wouldn't need any.
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-06-2008 10:48 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Sticking glass to glass problem scarf General DIY Discussions 2 09-24-2007 09:09 AM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
