Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-10-2009, 01:03 PM   #1
Unhappy
glass block vent removal and installation
I need to remove an old damaged metal framed glass block window vent and install a new plastic glass block window vent.
If someone will walk me through the process to accomplish this I will greatly appreciate it.
Sincerely,
James
JMuhammad is offline   Reply With Quote
Old 09-10-2009, 07:29 PM   #2
Concrete & Masonry
All I can say is "Good Luck". If you can find a way to remove the existing vent without at least cracking one surrounding glass block, your more fortunate than I've been. I would try grindign as much mortar out as you can from the outside & than try to "destroy" the vent inward. You might want to plan on replacing a few of the glass block, just in case.
jomama45 is online now   Reply With Quote
concrete paint removal before tile installation SR996 Flooring 1 03-21-2009 08:31 PM
