-   General Discussion (http://www.diychatroom.com/f2/)
-   -   glass block vent removal and installation (http://www.diychatroom.com/f2/glass-block-vent-removal-installation-52738/)
JMuhammad 09-10-2009 01:03 PM
I need to remove an old damaged metal framed glass block window vent and install a new plastic glass block window vent.
If someone will walk me through the process to accomplish this I will greatly appreciate it.
Sincerely,
James
jomama45 09-10-2009 07:29 PM
All I can say is "Good Luck". If you can find a way to remove the existing vent without at least cracking one surrounding glass block, your more fortunate than I've been. I would try grindign as much mortar out as you can from the outside & than try to "destroy" the vent inward. You might want to plan on replacing a few of the glass block, just in case.
