Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-20-2007, 06:49 PM   #1
GFI wont reset
Hi...I have a GFI plug in my garage, its the only plug in the garage. It tripped last night, now it wont stay reset. I left a small car battery charger plugged into it all night by accident. Also the outside outlets are tied into it too. But the outside outlets are covered by rain gaurds so I know moister in those outlets cant be a problem. Also, I bought a new plug and it does the same. Any help is appreciated. John
john49 is offline   Reply With Quote
Old 09-20-2007, 07:10 PM   #2
joed's Avatar
GFI wont reset
Disconnect the load connections and try to reset it. If it resets then you have a problem somewhere on the receptacles connected to the load side. Could be water in one of the outside receptacles. Could be bugs inside one of those receptacles.
Old 09-21-2007, 09:33 AM   #3
GFI wont reset
Check the down stream outlets as advised above. Sounds like you might find a fried roach or lizard.
Big Bob is offline   Reply With Quote
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
Comfortmaker Furnace/Blower - blowing reset switch tmarcel HVAC 3 09-06-2007 10:27 AM
Kitchen outlet breaker simma Electrical 3 02-28-2007 06:50 PM
My GFI sparked and won't reset pgallardo Electrical 6 10-17-2006 01:42 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 11:13 AM
