Getting A Standard 5' Tub Through RO - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 09:08 AM   #1
Rewards Points: 278
Getting a standard 5' tub through RO
OKAY. This one is going to have me scratching my head for a bit...
5x7 Bathroom.
Tub is running the 5' width.
Cast Iron...
Standard 30" Door.
Removing the old one is cake.
New unit will be 5' as well.
Just short of doing some quasi angle as I bring the tub vertical into the room, any ideas
how to get a 5' tub into a 5x7 room and laying the tub back along the 5' side.
The only option seems that the other 5' side of the wall needs to be demoed to get her in and just
run her up the side
mobiledynamics is offline   Reply With Quote
Old 10-23-2011, 09:40 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
5x7 Bathroom.
Cast Iron...
Standard 30" Door.
run her up the side
The only thing that will hang is the front edge of the tub, if the wall covering is gone at that point it should lay on down if the drain end is on the floor.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (10-23-2011)
Old 10-23-2011, 09:48 AM   #3
DIY staff
Rewards Points: 7,174
You will want to remove some drywall in front of the tub area---Bring it in on its drain end---
two strong people can set it down easily enough with one on the skirt side one the other on the back side. Then slide it into place---
It's 2011, why are these not standard safety devices? Red Squirrel Safety 16 04-21-2011 05:41 PM
Roman Facut - Replace Delta w/American Standard mormegil Plumbing 1 11-29-2010 08:37 PM
Rough opening too small for standard sized entry door... speedster1 Remodeling 8 10-12-2010 08:38 PM
Godman, Lennox, or American Standard homeowner12 HVAC 2 10-13-2009 06:54 AM
ICF or standard foundation ragweed Building & Construction 8 03-20-2009 08:11 PM
