Getting Heavy Items Into The Attic - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 08:20 PM   #1
Getting heavy items into the attic
Getting older and now with back problems, it is getting to be more difficult and riskier to get all those boxes of Xmas decorations up to the attic—and down. Our setup is a conventional drop-down attic ladder. I am thinking there has to be a way to rig a small block and tackle or a small electric winch that I could use to lift the boxes up and down while I am up in the attic.
I would bolt the winch or hang the block and tackle to a rafter. Let me add none of these boxes would weigh over 20-30 pounds.
Any suggestions? Or resources for this type of thing?
goodwood is offline   Reply With Quote
Old 01-01-2013, 08:31 PM   #2
Missouri Bound's Avatar
Try Harbor freight tools for a cheap 120v winch.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
goodwood (01-01-2013)
Old 01-01-2013, 09:32 PM   #3
Would one of those hand winches that are commonly used on boat trailers work?
Old 01-01-2013, 09:50 PM   #4
If it's only 20 or 30 lbs a simple pulley would work, a block and tackle arrangement would half the weight.
Old 01-02-2013, 09:16 AM   #5
Rewards Points: 24
Not original, and may not be the answer for everyone, but we took a differnt path a few years ago. Lights that I couldn't get to work within two minutes to the dumpster, a few ornaments, etc. to nieces and younger friends, a few more to the rummage sale, some more things that we didn't need cleared out of the garage, 12' of shelves from the floor to the ceiling, and all of the decorations are within the reach of a 6' step ladder. Still have a convenient drop down ladder to the attic, but no need to go there any more, other than for mechanical access.
The Following User Says Thank You to DexterII For This Useful Post:
oh'mike (01-02-2013)
Old 01-04-2013, 09:24 PM   #6
My wife has so much Xmas crap it is embarrassing and no amount of b*tching has reduced it over the years. I have told her that maybe she needs to buy one of those pre-made outbuildings just for the Xmas crap!
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 05:27 PM
