Genie Screw Drive - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 02:58 PM   #1
Genie screw drive
I have an older model IS550A that had the end bell bearing go bad. I ordered a new end bell and am putting it back together but I find I have forgotten where all of the parts go. If someone could tell me the sequence of parts internally, I would appreciate it. There is the armature, rubber washer, 2 metal washers, a spring, and a cup shaped piece of hard plastic. Thanks If I had to guess, I would put rubber washer on armature to screw end, then one metal washer, spring, cup, and washer to end bell. Close?
lhoyer is offline   Reply With Quote
Old 03-27-2012, 06:14 AM   #2
You should be able to find the owners manual, w/parts picture, online at Genie.
Old 03-28-2012, 08:47 AM   #3
I have not been able to find a manual online anywhere that show the arrangement of parts inside the motor. I was hoping a tech that was familiar with the insides of the motor could point me in the right direction. Thanks
Old 03-29-2012, 07:01 AM   #4
I have installed MANY of those Genie openers over the years, and a search of my file cabinet shows nothing of help. I suspect that since they have been making those openers for years, little has changed inside the box. Maybe one of their other manuals has the info you seek.
Robertson tip stuck in screw djgrant General DIY Discussions 4 07-05-2011 04:18 PM
Drywall screw gun or screw setter bit ? Arky217 Building & Construction 6 06-18-2011 09:22 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
Would you staple, nail or screw? Speedball Flooring 7 11-28-2008 11:21 AM
Wiring around screw terminals daxinarian Electrical 3 07-14-2008 04:41 PM
