Genie Garage Door Remote - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2008, 08:09 PM   #1
Genie garage door remote
Does anyone know how I can program my Garage door opener so that I can use more than one remote, I am following the instructions that came with the remote and also in the owners manual, It seems that after I press the learn button and get one remote to work, I program the second one and then lose the memory of the first one, I'm lost ,,, I have a Genie Excellerator Series 2 Any ideas? Thanks Dan
Bull-37 is offline   Reply With Quote
Old 01-10-2008, 07:38 PM   #2
Eibwen
Might try erasing all of the memory by holding the learn button for ten seconds or until the light goes out then reprogram each remote.
According to the manual I have they will only hold seven remotes.
After each programming make to sure to press the remote button at the end of the process to finish and turn off the learn light. then start with the next remote.
That thing does have a lifetime warranty and I have found thier tech and warranty support to be pretty good.
Last time I called for a manual inside button that broke, they sent me that and a motor controller circuit card for just the five buck shipping charge.
Sammy is offline   Reply With Quote
Old 01-10-2008, 08:56 PM   #3
I've programmed multiple remotes numerous times without a problem. Just check to see if any DIP switches are being used in the remotes. Look under the battery cover and observe how they're set. If there are DIP switches present and they are set the same, that may be the problem. Intellicode openers and remotes are a 1-2-3 exercise.
End Grain is offline   Reply With Quote
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 09:53 PM
