Genie Garage Door Opener - Wall Switch Won't Control LIGHT - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 03:22 PM   #1
Genie Garage Door Opener - wall switch won't control LIGHT
We just installed a new Genie Garage Door opener. The wall controller has a switch to turn the light in the controller on/off. The button does not work. That is, after opening or closing the garage door, the lights in the controller head just stay on - eventually time out.
The wall controller is just a 2 wire connection ... it either works (to control the head) or not (if wired backwards). The controls on the switch itself both illuminate as expected and it is not in a "lock" position.
Any ideas????
cody21 is offline   Reply With Quote
Old 12-08-2010, 08:33 PM   #2
Rewards Points: 6,652
What does Genie's 800# tell you when you call, same for the manual that came with it? Does the light even come on when you open or close the door?
Old 12-08-2010, 11:42 PM   #3
firehawkmph's Avatar
Rewards Points: 1,792
Cody,
You might have just got a bad wall switch. I have installed a lot of genies and never had trouble with the light button function. If you hooked the wires up properly, which sounds like you did since the wall unit buttons are illuminated, I would call genie and ask them to send you another wall unit.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-10-2010, 05:36 PM   #4
Thanks guys for your recommendations ... I called GENIE and they're sending me a replacement Wall Switch ... we'll see if that fixes this.
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
In Wall Programmable Light Switch amardeepj Electrical 7 10-08-2010 03:59 PM
Light switch in wet wall? rick112 Electrical 5 05-05-2010 12:10 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
