Genie Garage Door Opener - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 03:54 PM   #1
Light on power unit worked fine for years - - - shutting off after a certain time.
Then it would stay on past normal shut-off but could be turned off at wall console.
Then wall console wouldn't work and it couldn't be turned off at all.
Bulbs have been removed and I'm in the dark.
Is this a wall console issue?
A power unit issue?
Or something else?
Thanks for any help.
dim1946 is offline   Reply With Quote
Old 01-12-2014, 09:05 PM   #2
firehawkmph's Avatar
Rewards Points: 1,792
Dim,
What model Genie do you have and how old is it? There is a date code on the serial tag on the back go the opener. Last two digits are the year of manufacture. Sounds like a circuit board problem.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-13-2014, 07:26 PM   #3
It's a GXL9550 - - - installed in 1995.
According to paperwork, motor has warranty for as long as I own the house.
My guess is that probably doesn't cover the board if that turns out to be e problem?
Right?
Old 01-13-2014, 09:56 PM   #4
I doubt they would cover the board, but you could email them and ask, all they can say is no. The opener is going on 19 years old, I wouldn't put any money into it. Keep using as long as it works. I have five doors with five openers. 4 out of the five operate fine, the lone genie promax 500 does what yours does, no lights. But it goes up and down fine.
Mike Hawkins
Old 01-14-2014, 06:46 PM   #5
Thanks for the feedback, Mike.
Everything you said makes sense and I totally agree. I had sent an email to Genie but no reply yet. I think my next step will be a phone call to their 800 #.
I won't be putting any $$ into this one, but since it's still good mechanically, I may move it to the door at the 3rd stall in the garage - - - no need for lights there.
Thanks again.
Old 01-14-2014, 09:18 PM   #6
Good idea. I do the same thing. One of my doors is. 16' x 8' that's now inside after an addition. I always put an old opener I took off a job that still worked. First was an older liftmaster chain drive that was over 15 years old. Worked for over fifteen more. Replaced it with basically the same unit only three years old. Lady didn't like the noise it made.
Mike Hawkins
Old 01-14-2014, 09:37 PM   #7
Thanks for the "endorsement".
It sounds like you've got a lot more experience at this stuff than I do.
Old 01-15-2014, 07:52 PM   #8
I install garage doors and openers as a business, along with remodeling.
Mike Hawkins
Old 01-15-2014, 08:11 PM   #9
I finally got a reply from Genie. They described a series of tests to check the wall console, then the wiring to the power unit, then the circuit board.
Seemed to be fairly helpful - - - "do this and let us know what happens".
As to your last entry, I had a feeling you knew something about this stuff.
Thank you.
The Following User Says Thank You to dim1946 For This Useful Post:
firehawkmph (01-16-2014)
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 08:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 04:08 PM
Garage floor Tomperro Flooring 6 07-18-2011 01:30 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 09:53 PM
