GE SunSmart Digital TImer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 08:00 AM   #1
We have installed the above timer and have tried 10 times to get it to work correctly. I have followed the instructions exactly and yet it will not automatically start, we end up having to push the button to turn on and off.
Help
lilacorn1956 is offline   Reply With Quote
Old 10-23-2011, 09:41 AM   #2
Help
I'm having the same issue. P1 is programmed. Doesnt turn on / off automatically.
Comhertz is offline   Reply With Quote
Old 10-23-2011, 11:13 AM   #3
joed's Avatar
Rewards Points: 12,362
That unit appears to rely on sunrise and set times. Is there a clock in to set the time? Is the AM/PM setting correct?
The Following User Says Thank You to joed For This Useful Post:
grafton1948 (12-29-2011)
Old 03-21-2012, 09:36 AM   #4
SunSmart Digital Timer Trouble
I have the same problem. The lights will come on but not turn off automatically using CFL lamps.
WillBo is offline   Reply With Quote
Old 04-23-2012, 05:37 PM   #5
We are having the same problem too. This is the 2nd one we have installed, thought the first one defective. We have confirmed all wiring to be correct - neutral to neutral, power to power, etc,
We can manually turn on lights, and have programmed only the Automatic setting, leaving the 7 other's alone and still it will not turn lights on dawn or dusk.
wksbayer is offline   Reply With Quote
Programming the GE Sunsmart digital timer Maris Electrical 0 09-26-2011 04:57 PM
GE Smart Digital Timer Trevis Electrical 21 09-08-2011 10:17 PM
GE Smart Digital Timer Installation SJJane Electrical 4 09-08-2011 12:53 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 01:16 AM
GE Smart Digital Timer Will Not Work Manually dgbarar Electrical 3 10-31-2010 08:15 PM
