GE Electric Dryer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 02:28 PM   #1
GE Electric Dryer
Have a GE Electric Dryer model Number DBXR463EDOWW. The dryer is about 5 years old and yesterday the light inside the dryer stopped working. Initially I thought the bulb had burned out but after further realized that the bulb is still good and the dryer is no longer getting hot. I flipped the breakers off and then back on but the dryer still will not produce heat. Is the light stopping working related to the dryer no longer producing heat? The timer, and tumbler are still working. Any help would be great.
Ekelsay is offline   Reply With Quote
Old 11-03-2011, 02:44 PM   #2
Rewards Points: 6,652
Unplug and check the receptacle & cord.
Old 11-03-2011, 02:47 PM   #3
jburd964's Avatar
Rewards Points: 166
Appliance repair clinic . Com, They have professional appliance repair technician's on staff to diagnose your problem, all they want is for you to buy parts through them. I've compared their part prices to other and their competitive with Sears
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 11-04-2011, 08:57 AM   #4
I think your thermostat went out, I would check YouTube for dryer repair. My dryer went out, but mine is gas, so it was a little different. A multimeter and some snooping around, you should be able to fix'er up!
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 11-04-2011, 03:56 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 840
I'm assuming that it's electric?
If so, do like greg said....start checking voltages....you may have lost one side of the 240Vac.
ddawg16 is online now   Reply With Quote
Old 11-05-2011, 08:29 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
I experienced the exact same condition in our electric dryer. Turned out I had a breaker go south. Old pushmatic double pole fried on one side. It smelled like a dead mouse of all things so I instinctively dismantled the entire dryer before I considered checking the power supply. Silver lining: the dryer was thoroughly cleaned up just like new inside and out. And I am now less likely to skip trouble shooting.
PoleCat is offline   Reply With Quote
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 07:18 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Gas Dryer - Electric Dryer gannys General DIY Discussions 8 10-13-2008 05:50 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
