GDO Belt Tension - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 06:10 PM   #1
GDO Belt Tension
I just finished changing out an old Genie Screwdrive with a Chamberlain Belt drive. Everything work greats however, I'm not sure if it is normal for the Belt to sag this much the door is open:
When the door is closed, it looks like this:
Do I need to adjust something? The door belt does get tight as it moves but I'm worried that much slack may get caught on the trolley.
AndyM is offline   Reply With Quote
Old 01-16-2011, 07:55 PM   #2
I'm not the person that has an answer for you, but, that is a heck of a lot of difference between open (no pressure on the belt) and closed.
If anything I'd expect to see the slack on one side or the other depending on if it was pulling the door closed Vs pulling it open. Unless there is something within the gear drive that would allow it to do that. ???? I know on chain drives the chain will sag a bit on one side in the closed position. Not sure about a belt drive.
You might send an email with pic's to Chamberlain and see what they have to say. You don't want to overtighten it, you may have other problems in the closed position if you do.
Shamus
Shamus is offline   Reply With Quote
FWD Drive Belt Tension vabear Landscaping & Lawn Care 2 11-11-2010 09:40 AM
Washer: Loose belt - won't spin Hemingway Appliances 5 06-06-2009 05:35 PM
Belt care... RippySkippy Tools 3 12-25-2008 01:43 PM
Dryer Belt KB Services Appliances 2 03-07-2008 12:35 PM
help with timing belt rideandbefree Automotive Repairs 6 03-05-2008 06:16 AM
