Gate Post Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 10:18 AM   #1
Rewards Points: 358
Gate Post Question
I have a 5' wide area between my fence and my house, I was thinking about adding in a gate to separate my front and back yard, the only catch is I can only make it a singles gate because I have two drainage pipe on house side which will not easily allow me to bury a gate post there.
So my plan is to take a 4x4 post, bury it say 30+" into the ground and fill it in with concrete., then build a gate aprox. 54" wide and 36" tall or so. The gate is just to contain small dogs, so doesnt need to be huge. To help prevent sag I was thinking about getting one of these:
http://www.amazon.com/dp/B000Q82OYQ
Though only allowed for a max size of 48"x48" I dont see why it still will not work in my case..
Thoughts or ideas??
cbzdel is offline   Reply With Quote
Old 06-09-2013, 08:39 PM   #2
An extra few inches isn't going to hurt anything. Happy building!
Maddogmech1 is offline   Reply With Quote
Old 06-10-2013, 07:40 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
Over time the post itself will bend to the load if it is not also braced well.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-10-2013, 09:44 AM   #4
Rewards Points: 358
what would be a good method of bracing, I can not do any sort of metal wire tire back as I would be putting the post on the property line..
Maybe I should try out a steel post, no idea on cost or feasibility but I guess could be an option..
Old 06-10-2013, 11:54 AM   #5
You may want to check local scrap yards for a length of well casing. You can't bend that with a bulldozer, though it may be a little overkill. Also 4" sch 40 pipe full of concrete is a good alternative and quite rigid
Old 06-10-2013, 12:22 PM   #6
PoleCat's Avatar
I have seen effective braces done by putting an ornate top structure between the hanging post and in your case the latching surface.
Gap size between cedar post and gate? jmeander Carpentry 10 08-06-2012 02:00 PM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 09:31 AM
Fence Post Question handy man88 Building & Construction 4 06-14-2011 03:55 PM
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 08:18 AM
Gate Post Question AaronBerquist Building & Construction 1 08-19-2007 12:51 PM
