Gas Vent Pipe Getting Water Into It - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 10:21 PM   #1
Gas vent pipe getting water into it
My gas range vents throgh the roof it is getting water in the pipe, i tried changing the roof cap put on rainproof cap, still getting water in the vent pipe i noticed the pipe going through the attic and out the roof is thin alluminum but it is sealed and in good shape on roof, could this problem be from condensation or something else.
jwk937@hotmail.com is offline   Reply With Quote
Old 01-05-2009, 10:49 PM   #2
Registered User
Termite's Avatar
Probably condensation. Do you use it a lot, and is it cold outside where you live? The warm air in the vent hitting the cold pipe in the attic could lead to condensation. If it is a small residential range hood you can probably insulate the pipe to reduce this. If it is a larger hood, there may be clearance requirements to its vent. Check with the manufacturer of the hood to see if you can insulate the vent pipe.
Old 01-06-2009, 05:47 PM   #3
Thanks for the input
Thank you for the quick reply i will check into putting a heavier pipe or insulating the pipe thanks again
Tags
construction , general , hvac installation , roof repair
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
pipe layout and water flow moneymgmt Plumbing 4 01-25-2008 05:07 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
