Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-15-2005, 04:44 PM   #1
Jack of many trades
Gas Range
I am looking for someone that is abundantly familiar with repairs on a gas range, specifically switching one from propane to natural gas.
Any takers?:D
nicholasnettles is offline   Reply With Quote
Old 11-16-2005, 12:41 PM   #2
Gas Range
I would try my gas company first. Then you KNOW the quality etc. and you have somebody to talk to with any difficulties. If they cant or wont you know you probably shouldnt do it. Had water heater with same deal, wanted to go from gas to propane.. Said no way!!! They cant do that anymore without changing whole guts which is more costly than buying new. What an age we live in!!!
justdon is offline   Reply With Quote
Old 11-16-2005, 01:21 PM   #3
Jack of many trades
Gas Range
I have 1 burner and an oven that seems to work just fine. The range was originally made to be a gas range, but it was converted to take propane. I will see what I can come up with, maybe let you know how I did it (if I do it) for future reference.
Old 11-16-2005, 02:20 PM   #4
Gas Range
If they did it properly they put in different orifices. If they did it cheapo diy they took a electric drill to them and drilled them out Propane needs a bigger hole than natural gas. Dont ask me how much bigger tho, I wouldnt know!!
Old 11-16-2005, 08:18 PM   #5
Jack of many trades
Gas Range
I'm pretty sure they used the propane orafices and set the pressure regulator to take propane. As far as I have found out so far, I need to replace the orafices and set the regulator for gas instead of LP. Now, HOW to set that pressure regulator for gas seems to be the trick.
Old 11-17-2005, 11:50 AM   #6
Jack of many trades
Gas Range
**New Development**
At the botom of the range and behind the proiler pan is a pressure regulator. As I understand, LP and NG use different pressure settings on this regulator. The catch is that I can't really figure out how to adjust it. I did feel a switch behind it, and it feels adjustable to a degree, but I am scared of forcing it and breaking something.
So, Don ... or anyone, really....
I know I need to do 2 things. (1) replace the orafices (need smaller ones for NG) and (2) set the pressure regulator for NG which is now set for LP. I am pretty sure how to replace the orafices, but does anyone have any idea how to set the regulator?
Old 11-26-2005, 08:18 AM   #7
jeff1's Avatar
Gas Range
Hi,
Something here may help....
http://www.applianceaid.com/gas_range_convertion.html
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
gas range swap kenny11876 Appliances 2 02-20-2008 09:31 PM
Range outlet required? Doug_Shaver Electrical 2 06-12-2007 06:10 PM
Drop In Range Hook-Up mickey45 Electrical 1 04-08-2007 10:29 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
