Gas Line In My Garage? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 01:50 PM   #16
Find underground facilities and objects
The use of metal rods for dowsing are sometimes used!
I have often used this method of locating buried communications cables.
Its my belief that the earths magnetic field is distorted by buried metal and water mass's. By holding the rods very lightly, they pull together at the tips when the earths magnetic field becomes concentrated, much like the wind blowing between two large buildings!
Old 02-22-2010, 08:52 PM   #17
wow first time I heard about that.
Fraser20 is offline   Reply With Quote
Old 02-22-2010, 08:54 PM   #18
Rewards Points: 260
My girlfriend swears they don't work, but I'm with GBR. I think it's a water line.
jpearson311 is offline   Reply With Quote
Old 02-22-2010, 11:23 PM   #19
Well, I never detected any spirits with them, if thats what your girl-friend means!
However, it was my job to locate under-ground cables for my employer!
I used electronic equipment for this purpose, but always double checked it with the dousing rods!
The electronic equipment, allows you to hear the various magnetic radiation that exists all about us and its my opinion that its these same magnetic fields that cause the rods to pull together!
Magnetic lines behave much like rubber bands that are stretched. They want to constrict and they want to follow the path of least resistance. So, as the lines run through the rods, they exert a pull on the rod ends!
Thats my story, and I'm stickin' to it!
Old 02-23-2010, 09:02 AM   #20
Rewards Points: 260
Funny reply Wildie. I appreciate your help!
Jesse
Old 02-23-2010, 09:44 AM   #21
Household Handyman
Rewards Points: 1,408
Well, I've tried, more than once, to locate a known PVC water line with water in it, and the electrical line to my shop (direct burial) with dousing rods. I put them in, I know where they are. I'm not sure I even found the outer wall of my shop with these. That's just me. Some years back, I was working construction on an addition to a manufacturing facility. It seems everyone associated with the plant just knew there had been a new run of Natural Gas in this area within the last few years, but this had not been added to the plants blueprints, nor the City's. One of the trackhoe operators on site went to the shop, got two pieces of filler rod for welding and made him some dousing rods. He located the 2" pipe within about 15 minutes. He carefully dug down with his bucket until he scraped the pipe---NO marker tape. The plant Engineer bought him a case of beer. Now--IF I could just find my glasses. David
Old 02-23-2010, 09:49 AM   #22
Rewards Points: 260
What do you guys think the smaller pipe is in the picture? The one closest to the ground and bent to the left?
Jesse
Old 02-23-2010, 12:51 PM   #23
Jesse
I think that its a gas line! Notice that the galvanized pipe hasn't rusted, whereas the black pipe has. If it were a water line it would have been galvanized also!
It has half of a pipe union on the end that looks like it connected to a stove or a water heater!
Old 02-23-2010, 01:04 PM   #24
Rewards Points: 260
But it's not capped. Should I be worried about that?
Old 02-23-2010, 10:57 PM   #25
It obviously is disconnected, or at least shut off, so I can't imagine that its a problem!
It must have been connected to the meter at one time, and if you examine the area around the meter, you may or may not find the other end of it!
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
Water supply line replacement bamaknox Plumbing 2 01-08-2009 08:51 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
