Gas Furnace - Texas - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 02:12 PM   #1
Gas Furnace - Texas
1 - Is it legal for me to work on my own gas furnace?
2 - if I perform work on my furnace is it illegal for a company to come out and work on it for something else?
MM227 is offline   Reply With Quote
Old 12-08-2011, 03:01 PM   #2
biggles's Avatar
your paying the mortgage....as long as it's safe and as for having companies follow you up sure if you tried a parts change and it just sits....
Old 12-08-2011, 03:09 PM   #3
Rewards Points: 338
yes, you can work on it yourself and yes, you can have another company follow up. however, just like a professionally hired contractor, you are supposed to do your due diligence to follow all local codes and make sure anything you work on you update to current code if necessary.
NitroNate is offline   Reply With Quote
Old 12-08-2011, 03:24 PM   #4
Thanks guys. Here is the background:
1-Had an estimate from a company.
2-Replaced the two part they suggested (ignitor and gas valve)
3-didn't fix it.
4-Had another company come out to check my work because they could make it out faster.
4-replaced control board
5-called company #2 to come out to check work and advise on arching issue.
6-refused to come out because I replaced parts (they knew that I replaced previous 2) and said it was illegal for me to work on it without a license.
wanted to make sure it was okay before moving to company #3.
Old 12-08-2011, 07:36 PM   #5
biggles's Avatar
without saying anything a good tech will see what was changed with new stuff on a walk in...do you still have no heat and did #3 show up....your running out of stuff to change what is and or isn't going on the call for a for heat....next time somebody comes in and bangs you for a service call? quip...don't bother i'll go over to DIYchatroom to talk to the pros for FREEEEEEEEEEEnobody tells you what you can and or can't doin the castle
Old 12-08-2011, 07:50 PM   #6
Rewards Points: 582
what was the oringinal problem and is it fixed yet....
Old 12-08-2011, 10:19 PM   #7
Not fixed yet. Having an arching problem or something that sounds like it. I didn't call #3 today...I'm ignoring the big pink elephant for tonight.
The problem now is right when the blower kicks on after the heat up...I get a crackle sound or arching.
Anywho...I'll keep updating as this story continues.
And yes...it is my castle. Boo-yea!!
Old 12-09-2011, 10:38 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
Some ignitors make a popping/ cracking sound. If it is functional declare it fixed. I am always amazed at the garbage that comes out of "professional's" mouths. Sleazy lawn service dick told my aunt it was illegal for her to buy weed & feed at Lowes and apply to her own lawn because she wasn't a PhD in lawn care like he was. I got the turd fired.
PoleCat is offline   Reply With Quote
Old 12-09-2011, 11:00 AM   #9
@polecat - the popping sound is VERY loud. I can hear it in the house. This is why I'm concerned. The only time I've heard something similar is right before a transformer blew when I was a kid. Granted the transformer was much louder....but same type of sound.
Old 12-09-2011, 11:25 AM   #10
biggles's Avatar
is there a burning wire smell like a toaster elements with the burner cover off how is the flames and has the spark ignition stopped after the main burners are on...so the unit is making set point but the noise and neither parts change any sounds....but you still have original noise....do you have a plain cardboard/fiberglass filter or electronic?
Old 12-09-2011, 11:42 AM   #11
No electric short smell now that I think of it.
The ignitor is a glow rod. It gets white hot then the gas kicks on. Right when the blower kicks on the noise starts.
I would like to see if it stops but I don't want anything else to short out and I certainly want my house to catch fire.
Old 12-09-2011, 11:43 AM   #12
Filter...the one in the house? Is there a filter in the furnace?
Old 12-09-2011, 01:38 PM   #13
biggles's Avatar
could be something flapping in the duct now this is on the heating side... if you have AC what sounds do you get in just FAN/ON only off the stat
Old 12-09-2011, 01:42 PM   #14
No sounds with AC or fan only.
Only does it with the furnace.
Old 12-09-2011, 01:58 PM   #15
biggles's Avatar
could be the heat exchanger expanding getting hot then cooling down after the stat satisfies...do you hear it after the main gas shuts down,but the fan is still running at the end of the heat cycle?especially if your right down in front of it...160F + going into that duct from the furnae is it sheetmetal on the main run out up into the house?
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
