Gas Fireplace Smells Like Kerosene ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 03:43 PM   #1
Rewards Points: 264
Gas fireplace smells like kerosene ?
For some reason my fireplace smells like kerosene. I'm painting, but not really near the fireplace, and the smell doesn't seem to be near the paint.
Any idea why I'd be smelling kerosene all of a sudden? Only thing I can figure is maybe the paint is giving off vapors that don't smell until they hit the fire?
I shut off the fireplace, but it's still really weird.
tibberous is offline   Reply With Quote
Old 01-29-2012, 04:27 PM   #2
DIY staff
Rewards Points: 7,174
That happens a lot when I'm using oil based poly---the oven will do it too.
Makes you realize how much nasty stuff we are breathing---
Old 01-29-2012, 04:47 PM   #3
Too Short? Cut it Again!
Hopefully your are drafting even a gas fireplace?
Got a small glass? Just a reminder lesson coming. Put an inch of water and inch of salad oil in it. I hope you see what I always do. Oil is on top right? It is lighter than the water?
Same with the atomized vapors from either. The draft from the fireplace is catching those from the oil paint first, faster and before water vapors in the room. And it is combusting them. The result is the odor you smell.
Has to happen this way.
If it really bothers you. Close the damper. Keep the fireplace off until you are done. If it has a pilot light, kill that too.
Need a lava lamp by the way? This is where the originals came from and one company still makes them. Take about really cool use of floating oils in heavier solids. Of course I own hundreds.
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
