Gas Fireplace Remote? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 01:19 AM   #1
Rewards Points: 358
I do not have the owners manual for my firpalce, I am trying to hook up a remote rocker switch that was installed by the prvious owner. The problem is that the previous owner wired it for 120 volts and actually shorted out the entire fireplace valve. The valve has been replaced and is now in perfect working order.. Now I want to hook up the remote correctly. For what I understand I need to just get a 120 to 24 volt converter and your good to go. If this about correct?
Thanks!
cbzdel is offline   Reply With Quote
Old 05-29-2010, 05:56 AM   #2
There should be a manufacturers name on the gadget somewhere, contact them for specifics.
Old 06-05-2010, 10:18 PM   #3
There should be some sort of ID tag on the fireplace. Post that info or contact the manufacturer. Most gas fireplaces do not operate on 120v or 24v, they operate on a Mv system.
log_doc_rob is offline   Reply With Quote
Old 06-07-2010, 06:11 PM   #4
Rewards Points: 358
I will try to get some more specs.. I know its an Empire unit.
Old 08-10-2010, 09:24 AM   #5
Most electric remotes have a plug in to supply power and then two switch legs which go to the switch wires on the fireplace. These wires as Rob said do not carry household current. There are also battery remotes where the receiver works off batteries also. They would only have the switch leg wires and not the power wire.
ausblake is offline   Reply With Quote
Old 08-11-2010, 05:53 AM   #6
Rewards Points: 5,336
You want the name of the remote to get the manual. Get on their website to download the wall switch specs.
Ron
new opening in fireplace? burningbaal Remodeling 3 10-11-2009 01:18 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 08:10 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
