Gas Fireplace Not Working - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2016, 12:05 PM   #1
Rewards Points: 2
Gas Fireplace not working
Did not know what subject to put this under, so here goes. I have an RH Peterson realfyre gas log G10-24/80 01V vent free. Trying to start it up for the first time after the summer. I am able to light the pilot light and it stays lit. I am also able to light the main burner, but it does not stay lit. It may stay lighted from anywhere from 5 seconds to a minute and a half. The only thing that happened during the summer when it was off was we had a hurricane roll through and got some rain down the fireplace and I did get some water onto the log set. Not alot, but I was hoping this is not the cause of it not staying on. Thanks in advance for any help you may give.
kburnham is offline   Reply With Quote
Old 10-23-2016, 07:39 PM   #2
Rewards Points: 232
Re: Gas Fireplace not working
Welcome to the forum kburnham.
I agree with you, I think when it was exposed to the water, the burner may have gotten rusted and corroded a bit causing an insufficient gas flow. Probably just needs to be taken apart and cleaned really good. Burner, pilot, etc.
Follow the instructions in your manual on how to do this or call the manufacturer for assistance.
Try giving it a really good cleaning and see if that helps.
jmon is offline   Reply With Quote
In wall fireplace install options & insulation Boydrone Building & Construction 5 01-05-2016 08:59 PM
Removing a brick fireplace vestaviascott Concrete, Stone & Masonry 8 10-26-2014 02:56 AM
Cold air near fireplace - normal? darthsmozers HVAC 7 12-13-2013 11:07 AM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Cantilever Fireplace? diyisalotoffun Building & Construction 11 06-06-2011 03:34 PM
