#1 |
Gas can leaks gas
I have one of those no-spill 5 gallon red gas can containers in my garage. Whenever it gets warm gas tends to leak out of the black plastic cap. I don't understand....?
I tried loosening the cap up to let some air out, but that doesn't seem to help. |
#2 |
Pro Flooring Installer
Gas can leaks gas
Gas expands when it gets hot.
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 |
#3 |
Gas can leaks gas
lower the level of gas in the can. when it expands, it needs to be below ANY opening.
#4 | |
Gas can leaks gasQuote:
#5 | |
JOATMON
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 | |
#7 |
Gas can leaks gasto avoid, simply do not fill so full. if you notice, when empty and filling, five gallons does not bring it up to the level of the cap. the manufacturer has allowed fr the expansion by giving extra rom in the can for expansion. I suspect when you fill it, there are more than five gallons in the can. |
#8 | |
#9 |
Master General ReEngineer
Gas can leaks gas |
#10 |
Gas can leaks gas
I'm got tires of the piece of crap plastic cans and purchased 2 5 gallon steel Eagle gas cans. A local hardward store had them on sale for $34.99. Not cheap but at least they don't leak and they're American made.
#11 |
Gas can leaks gas |
#12 |
Gas can leaks gas
I assume this thread is a joke and we have all been pranked.
#13 |
Gas can leaks gas
I wonder if the gas is being forced up through the no spill vent tube or even the retracted fill spout in which case it would not matter how full it is if its being forced up from the bottom with heat expansion. I say replace the can.
#14 | |
#15 |
Gas can leaks gas
Is this what you have?
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10102.html It has been recalled which means you should get a refund. |
| Display Modes | |
| ABS drain pipe leaks under pressure test | abracaboom | Plumbing | 12 | 01-24-2012 08:27 PM |
| 3 season room roof leaks | rod altman | Carpentry | 7 | 12-22-2010 10:56 AM |
| Ridge Vent: Cause of massive leaks? | ShortEdged | Roofing/Siding | 28 | 08-26-2010 11:15 PM |
| Flat roof - Rolled? - leaks Advice? | JJ2001 | Roofing/Siding | 4 | 11-19-2006 07:17 AM |
