Garden Window Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 09:03 PM   #1
Cool
garden window question
I would like to install a garden window (greenhouse window). Does anyone know who makes the best one? Has anyone had any troubles with these? Should I get low e coating or does that filter out the UV that the plants need?
Vivian
viviank is offline   Reply With Quote
Old 05-27-2009, 06:56 PM   #2
I have the same questions! Anyone out there that can advise? Thanx!!
jo4sho is offline   Reply With Quote
Old 05-28-2009, 07:31 AM   #3
It may not be a case of which is best. There are few manufacturers still making them, they were plagued with problems. Keeping them leak free was a major problem. The few still around are likely not worth buying.
Old 05-28-2009, 11:03 AM   #4
Rewards Points: 3,130
DON'T DO IT!! You WILL be sorry. I have one in a house I own in southern Maryland, and also installed one a few years ago in another house I owned at the time. Both leaked and were/are very drafty. They are also single-pane glass so are not energy efficient at all. If I weren't selling the MD house I'd tear the thing out.
Old 05-28-2009, 08:10 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
I used to install them for window world and the way theirs was constructed was quite different from others I have removed. Instead of attaching to the house they have an integrated oak/birch jamb extension that slides into the wall, flush to the sheetrock on the inside. This eliminates draft, and greatly reduces the chance for leaks, especially if installed on a house with brick. They are custom made to fit the opening. Some I installed had low-e (and double paned) but I don't know if this affects the growth of the plants or not. I know that they were very expensive. I think they ran between $1700-1900 dollars. I don't know what they run these days.
Man of many hats
wrangler is offline   Reply With Quote
Tags
best windows , greenhouse window , low e coating
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 12:56 PM
Sealing garden window properly bluefitness Remodeling 7 12-01-2008 11:10 PM
Yet another window question tpagel Carpentry 1 07-21-2008 11:51 PM
