Garage Ventilation Intake Vents
3K views 2 replies 3 participants last post by  Gary in WA
I am working on my attached garage and will ultimately be closing up the now open 2x4 walls. Ventilation includes 2 "suicide" vents just above the sill on the wage opposite the garage door and a turbine near the ridge.
I'd like to fancy up those vents. They are rectangle wire mesh. I'd like to put in a louvered vent with ducting that is somewhat nicely finished on the inside after I get the rock up.
I've found plenty of louvers, but what can I use for duct to get the air into the garage and not the inside of the closed wall?
Thanks!
I'm confused.
#1, Need to go back and add your location to your profile for better answers.
Just go to quick links to edit.
#2, No clue what a suicide vent is.
#3, By code there was supposed to be 5/8 fire rock sheet rock on any wall and all the way to the rafters to separate the garage and main house.
#4, No clue what you mean by what you mean by the "wage".
There should have been soffit vents and a ridge vent, that's all the venting you would need.
Got a picture of this garage?
Those vents were an anti-carbon monoxide requirement in the 1980's by FHA to exhaust (high vents on opposite wall) and low- intakes, as you have. They may not be required anymore... check with local AHJ. To keep them buy/install some rectangular sheet metal for a box through the wall with insulation around (though that alone is counter-productive...) :)
Gary
