Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-04-2012, 10:14 PM   #1
Garage Plans
Does anyone have a good resource for garage blue prints/plans? Are there better sources than just library books? Not sure where to go here...thanks!
DIYChick45 is offline   Reply With Quote
Old 04-04-2012, 10:17 PM   #2
Garage Plans
Google garage plans thousands come up. Lowes has lots of garage plan books.
Old 04-04-2012, 11:02 PM   #3
JOATMON
ddawg16's Avatar
Garage Plans
Depends on where you are and what you want to do and what the local regulations are in your area. (it helps to have your location in your profile.)
Some cities will give you a permit based on a sketch on a piece of paper....others want real drawings.
If you want to get some good info on Garages...check out
http://www.garagejournal.com/forum/index.php
That is all they do over there.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 04-05-2012, 01:12 PM   #4
Garage Plans
Your local independent lumberyard more than likely has some mockups that you can look at, to determine how purely functional or extravagant you wish to go, as well as plans. If you do a simple comparison, their prices may be slightly higher than the local big box, which they could very well be, but you may also find that there are differences in what they consider basic doors, windows, etc. While you are looking at plans, keep in mind that this is the time to decide what kind of storage you want, if any, overhead; many times, the assumption is made that there is "all that space up there", but because standard trusses were used, adequate support is not provided.
Old 04-05-2012, 01:20 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Garage Plans
If the book from a Library has plans in it, or it is on Building garages, you pretty much are going to find the same. It is what you want inside the garage, that maybe you are looking for. Storage, work area, etc. That would be up to you, since plans are not always a one fits all.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 04-05-2012, 01:24 PM   #6
In a little over my head
Garage Plans
What are you building? A new free standing detached residential garage? Renovating an existing garage? Will it be used for parking/storage/workshop?
ratherbefishing is offline   Reply With Quote
Old 04-05-2012, 06:34 PM   #7
Garage Plans
http://garageforum.net/forumdisplay.php?f=6
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is offline   Reply With Quote
Old 04-05-2012, 06:49 PM   #8
Garage Plans
Residential two car detached. Removing a one car and replacing it with a two car 20x24 or something similar (not smaller). Nothing fancy, just need plans. I went to Lowes today and they had ONE book on garage plans. You buy the book for 35 bucks and inside you see a nice picture of a garage and then send away for plans for another 35 bucks or so.
Old 04-05-2012, 07:02 PM   #9
MarginallyQualified
Garage Plans
Residential two car (and a half plus yard tool shed) detached. Removing a one car and replacing it with a two car 20x24 or something similar (not smaller).
Overhead doors don't need to be wider than 8 feet...
but almost no one allows for enough aisle space at the car doors and between the cars and the inevitable junk accumulation space too.
Try to be the exception.
Old 04-05-2012, 08:38 PM   #10
gregzoll's Avatar
Garage Plans
Better off going with a 2 1/2 bay with a third "shed garage next to it for storage of lawn equipment and the such. My BIL has a three car and on the end, a shop area attached to it, that is now being used for storage. What is your total budget for this project right now? That can help in suggesting what you may be able to afford in how big you can go.
Old 04-05-2012, 08:50 PM   #11
Garage Plans
My yard is only 50ft wide but very deep with a ravine and I don't want to go too wide or it'll hinder the view. My budget is about 17K.
Old 04-05-2012, 10:15 PM   #12
JOATMON
ddawg16's Avatar
Garage Plans
17K? GFL.
I would suggest clicking on the link in my sig..the one that says "Garage Build".....I did ALL the work (except foundation and stucco) and total cost was around $30K
And because mine is 2-story is not the main reason for the costs....at most, the 2nd story added maybe $2K in material.....labor was free....
My
and
Old 04-05-2012, 10:44 PM   #13
Garage Plans
Originally Posted by ddawg16 View Post
17K? GFL.
17K in S. California isn't 17K in Ohio let me tell you. The last quote I had was 23K. I think I can do better if I partially build it myself with a set of plans. I'll have to contract out the footer and all concrete work...and removal of concrete. I can do the demolition (minus concrete) for $250.
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
