Garage Opener Light - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 12:12 AM   #1
garage opener light
I'd like to wire my garage opener light to turn on from a switch from the side door entrance so I'll be able to see when coming in the side door at night. Am I able to do this using a door bell switch or possibly even a second console?
Thank you in advance,
Michael
Intenseman is offline   Reply With Quote
Old 10-01-2012, 08:42 AM   #2
custom user
Rewards Points: 150
I believe it's controlled by the circuit board to time out after so many minutes. So it would be far easier to simply wire up a separate light using traditional methods, why reinvent the wheel?
JasperST is offline   Reply With Quote
Old 10-01-2012, 10:07 AM   #3
Those are wired into a circuit board. The wall switch that I have for my opener has a motion sensor in it that turns the light on when anything moves. You could look into replacing what you have on the wall with one of those. I'm not sure it's possible but you can check with the manufacturer of your opener.
NHtransplant is offline   Reply With Quote
Old 10-01-2012, 10:50 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 850
Your opener should have an option for a wall mounted unit that also includes a light button. Mine has one.
Get the model # off your opener and see what options are available for it.
Most of the newer ones use 2 wires to control all the functions....so just installing a simple button is not going to work.
Old 10-01-2012, 02:53 PM   #5
So would I be able to wire up a second console near the side entrance so I would be able to turn on the light as opposed to wiring up a separate light and a 3 way switch?
Thanks,
Michael
Old 10-02-2012, 01:56 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 850
You should be able to.....get the model # off your opener and check the web site of the manuf.
Old 10-04-2012, 06:30 PM   #7
I have an alternate solution which might work better for you. Most garages are also wired with ceiling lights with a switch located somewhere in the garage itself. What you can do, is to replace the standard on/off switch with a motion sensing one that automatically turns on the light for you. This way, your garage will be automatically light with more lights when you come in with your car, or if you enter via a side door and the motion sensor detects your movement.
bigbearbear is offline   Reply With Quote
Old 10-04-2012, 06:52 PM   #8
Rewards Points: 268
I wanted a light in a window in my detached garage for early mornings, one that shined thru a bit to light up the outside door and the inside. I bought a little plug in box that is controlled by a little fob (like you have for keyless entry on a car). I bought a plug in light bulb adapter, screwed a flood bulb into it, and plugged the box into a ceiling outlet near the window. Perfect!
I also use it sometimes with Christmas lights. Best $15 I've spent in a long time. The fob works up to about 150' away by my testing. Just an idea.
Marqed97 is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage opener bulbs Zamboknee Electrical 2 07-08-2011 11:55 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 04:36 PM
Garage Door Opener Saga- Why DIY does NOT mean so-easy-anyone-can-do-it Leah Frances General DIY Discussions 6 12-14-2008 03:04 AM
