Garage Motor Keeps Running When Opening Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 12:08 PM   #1
Rewards Points: 99
garage motor keeps running when opening door
Hello,
As I opened the garage door this a.m. the motor would not stop running unless I pressed the button. I have kayaks that I used this weekend that hover over the motor. Don't remember making contact with motor as I took down the kayaks but there's a possibility. Any feedback would be truly appreciated, thanks all in advance!!
er78mph is online now   Reply With Quote
Old 04-29-2013, 12:12 PM   #2
firehawkmph's Avatar
Rewards Points: 1,868
er,
need some more info, brand of opener and what type, (chain, belt, screw drive,etc.). Also a few pics would be helpful.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-29-2013, 12:22 PM   #3
Rewards Points: 99
I believe its an older Genie model with a chain drive, ill have pics up by tonight. Thanks!
Old 04-29-2013, 01:10 PM   #4
Remodeler
Rewards Points: 320
Most models of Genie openers have the travel limit switches up on top of the rail, they are tripped by a trigger attached to the chain or by a tab on the trolley.
The wires or the switches can be moved, disconnected or damaged if you are storing things above the opener. The trigger pieces can work loose or be dislodged from the chain also.
iamrfixit is offline   Reply With Quote
Old 04-29-2013, 05:38 PM   #5
Sounds like a bad limit switch or wire to switch/control board.
Exjay is offline   Reply With Quote
Old 04-30-2013, 07:47 PM   #6
Rewards Points: 99
Here is my predicament: no obstructions(manually open and closed door), track is well lubed, all wires are connected. Yesterday morning the door would not go down and this afternoon the door won't open. motor turns on but it seems that it does not want to pull.For a while today it would close on his own but now it won't even do that. Seems like garage door opener is running out of juice or could it be the track?
Old 04-30-2013, 08:41 PM   #7
how old is the unit? springs worn/broken? maybe bad spot in the motors windings? coupler on motor worn/stripped or shot? Just throwing out guesses/suggestions here.
Old 04-30-2013, 08:52 PM   #8
Rewards Points: 99
Springs seem fine, unit
no older than 10 years, and that's about all the questions I could answer
Old 05-05-2013, 06:20 PM   #9
How about a clutch? Slipping?
eagle1015 is offline   Reply With Quote
Old 05-05-2013, 08:01 PM   #10
Rewards Points: 99
Yes!! Was the coupler, bought a new coupler from a local company and the door is working as good as new!! Thank you!!
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 08:12 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Moving interior door to garage - awkward? violetUK Building & Construction 3 12-05-2009 09:40 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
