Garage Floor, Foundation, Footer Questions? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 01:30 PM   #1
garage floor, foundation, footer questions?
Hello, I want to build a four car garage here in northeast Penna. I want to have the concrete/block work completed by a contractor, and then I will construct the stick built structure. I have a number of questions so that I can evaluate the contractors suggestions. there is asphalt presently in this area.
1 What is an appropriate grade of concrete, and thickness for the floor?
2 What is the proper substrate for under the floor?
3 What is the proper footer size and depth? (2 story gambrel structure)
4 what would be the appropriate height of the masonry foundation(probably cinder block) above grade?
I know much of this will be addressed in local building codes. I'm not looking for minimum permissible, but rather reasonable guidlines that will result in a quality, lasting structure. thanks in advance, greg
wengr is offline   Reply With Quote
Old 03-24-2009, 09:01 AM   #2
Registered User
Termite's Avatar
The answers to all four of your questions are very site-specific and project-specific. Conditions such as soil type, local codes and the structure's imposed loads will dictate footing size, depth, concrete strength and reinforcement etc.
You need to consult with a structural engineer to get these questions answered.
Insulation questions for new detached garage mpt1123 Building & Construction 2 03-01-2009 09:18 AM
Some questions about installing new garage door on old opener and other stuff Skeletor916 General DIY Discussions 2 01-23-2009 05:51 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
New detached garage, wiring, questions gp_wa Electrical 9 12-04-2008 04:10 PM
Garage foundation questions Don-NH Building & Construction 2 04-16-2005 01:03 AM
