Garage Floor Epoxy Coat Finish - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 09:02 PM   #1
garage floor epoxy coat finish
What's the main difference between a 1 part and 2 part epoxy garage floor finish? I know you can do the metal flakes with the 2 part and the 2 part cost about twice as much but does that make it twice as strong or twice as good?
Thanks,
bcw0801 is offline   Reply With Quote
Old 05-04-2011, 09:25 PM   #2
Rewards Points: 1,016
I used the rustolium kit several years ago on my garage. Was easy to do and has held up well. Prep is the key no matter what product you use. Got to get the concrete clean of any oils or stains.
____________
Vince
Old 05-05-2011, 07:12 AM   #3
Typically, an epoxy is a two part mixture, otherwise, it is just paint. One part is base, the other part is the activator. Once mixed, there is usually an active time when the product MUST be used. Once past that time, it will begin to set and becomes useless. The cured product is usually much harder and durable than ordinary paint.
The Following User Says Thank You to Just Bill For This Useful Post:
bcw0801 (05-05-2011)
Old 05-05-2011, 07:40 AM   #4
NACE Coating Inspector
mustangmike3789's Avatar
i had a concrete coating buisness for many years and have had to remove the one part water born epoxy that was sold at HD on several occasions. lots of bonding issues on concrete and it doesnt seem very durable. i removed about 1700 sqft for a guy that worked at HD because he listened to his co-worker in the paint dept.that told him that it would be ok to put it over xylene based solvent sealer. that was good for me because it came up really easy. i always use a good 2 part from PPG,surecrete or marblelite. marblelite sells the flakes by the pound for 1/3 the price of box stores, but i was also buying 50# min per order. they will also make any color combo that you want .
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
Tags
epoxy floor , epoxy garage , epoxy information
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 10:33 PM
Mudding Finish Is Showing on Final Coat Hages Painting 7 03-19-2007 11:09 PM
finish coat over painted walls a_theater_god Remodeling 2 07-30-2006 11:27 PM
