Garage Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 06:51 PM   #1
Garage floor
Can i have a concrete floor poured over blacktopped garage floor? One car garage adjacent to enclosed back porch that has entry door into kitchen. Present garage floor is cracked and crumbling; dirt and debris are tracked into the house. What would be best recommendation? Would be hiring someone to do work.
fgreenfi is offline   Reply With Quote
Old 01-31-2010, 07:31 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
Fg,
Have the cement contractor tear out the asphalt. If it's already crumbling and he has a bobcat, it shouldn't be any big deal. Do it right the first time.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-31-2010, 08:16 PM   #3
ok. Thanks. Is this an expensive process?
Old 02-01-2010, 08:09 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... It's mostly Labor,... It'll depend on your area.... Probably not Cheap...
Old 02-01-2010, 08:16 AM   #5
Rewards Points: 5,336
Garage floors aren't generally blacktopped, originally. They would be concrete slabs that were topped with asphalt when the owner did the driveway. It's not a good idea to push concrete against the framing members of the garage. It promotes rot.
Try doing a small exploratory excavation in a corner to see what's there.
Ron
Old 02-01-2010, 08:58 PM   #6
Hey Ron,
Here in northern Ohio, many of the small, post WW2 houses were built with detached, shed-roofed garages. Many of these had blacktop originally installed. It was common job later on when the floors went bad to jack up the garages and pour a concrete slab with a curb. Back in the mid-seventies it was a 500.00 job. That was quite awhile ago.
Mike Hawkins
[quote=Ron6519;392629]Garage floors aren't generally blacktopped, originally. They would be concrete slabs that were topped with asphalt when the owner did the driveway.
Old 02-05-2010, 12:26 AM   #7
Garage Detailer
Garage Detailer's Avatar
You should completely remove the decaying surface and be sure a proper vapor barrier is installed prior to pouring the slab. After a solid month of curing time, you could apply a sealer or decorative coating such as epoxy to make it look really nice.
I'm not sure the exact condition of the current surface, but if it's still relatively smooth, you can buy a snap together flooring product such as RaceDeck to cover it up and keep from tracking into your home.
Garage Detailer is offline   Reply With Quote
Old 02-05-2010, 08:51 AM   #8
Thanks for everyone's suggestions. Once I get some estimates, I'll be back for your input.
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 10:09 PM
Garage floor steam cleaning drpcken Flooring 2 03-06-2010 02:57 PM
Garage Attic Floor Joists zacmac Carpentry 3 11-02-2009 09:07 PM
Sloping a garage floor Jim Hart Building & Construction 13 04-30-2009 08:33 AM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 03:57 PM
