Garage Door Window Freezes Others Don't? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 12:21 PM   #1
garage door window freezes others don't?
I am trying to figure out why the 2 overhead garage door window panels have ice and condensation on their insides while at the same moment the double hung and regular entry door to the outside (window) do not have ice or condensation on them. ANy ideas?
docdeb27 is offline   Reply With Quote
Old 01-12-2014, 12:25 PM   #2
Gymschu's Avatar
Rewards Points: 460
Garage doors being metal would generally produce more condensation and the surface of metal is colder than air temps so it's freezing up there rather than windows and doors which are wood or at least have wood cores. Just a theory.
Gymschu is online now   Reply With Quote
Old 01-12-2014, 12:28 PM   #3
Back door is also steel and garage doors are insulated. Not sure if back door has a wood inside or not. But why the condensation(water) on the inside when the other window and door in garage (same temp) don't have any?
How do I remedy? The windows are always full of h2o or ice.
Old 01-12-2014, 12:43 PM   #4
Gymschu's Avatar
Rewards Points: 460
I would try to install plexi glass type coverings over the windows, much like the effect of a storm window. Plexi can be cut to exact measurements and can be purchased at a hardware store or big box store. I have had luck doing this with some of my own windows that were odd sizes and froze up like you have described. Of course, you may not want to be drilling holes to install the plexi in your nice, insulated garage door. It may void any warranties. Hopefully, others come along here with even better ideas.
Old 01-12-2014, 12:56 PM   #5
I appreciate the suggestion. Seems to me that if I spent all this money on top of the line Carriage type doors, this shouldn't be happening.
Old 01-12-2014, 04:14 PM   #6
Rewards Points: 5,974
Sounds like the garage are single pane glass.
Old 01-12-2014, 04:20 PM   #7
Rewards Points: 678
If you were to check the temperature of the two glass panes you'll probably see the temperature of the wet glass to be below dew point temperature while the dry pane is above dew point. It's colder for some reason we can't really tell from a distance.
Old 01-12-2014, 04:20 PM   #8
Gymschu's Avatar
Rewards Points: 460
Also, it never hurts to contact the company that installed the doors or even the manufacturer to see what they suggest. They see these types of problems all the time and can likely suggest a possible solution.
Old 01-12-2014, 09:01 PM   #9
firehawkmph's Avatar
Rewards Points: 1,822
Entrance doors have thermopane glass in them. Garage door windows are usually not. Most of the time they are single pane, depends on the manufacturer. Garage doors are not built to be as airtight as entrance doors and house windows are.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-16-2014, 08:56 PM   #10
Try placing a warm heater on the inside to melt the ice, scoop the ice off the door tubing manually or pour extremely hot water on the ice and yank the door immediately since the water will freeze.
stephensandy is offline   Reply With Quote
Old 01-16-2014, 11:22 PM   #11
Davejss's Avatar
Rewards Points: 740
If they are single pane glass they will ice up. I've never seen double pane, insulated glass in a garage door, but I'm pretty sure they have them. Perhaps the manufacturer of your doors has a retrofit option.
Davejss is offline   Reply With Quote
Old 01-17-2014, 06:31 AM   #12
Rewards Points: 1,294
What the heck are you talking about???????????? You pour hot water on cold glass and it will shatter. Not sure why you need to yank it open when the glass is frosting over.
danpik is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
unconditioned garage reillyoevans HVAC 3 08-20-2011 07:29 PM
