Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-27-2010, 11:27 PM   #1
Garage DOOR WAY OFF DUE TO uneven slope!
I have the same problem. I was told a bottom astragal would only cover two inches. My garage doors are hung right but my concrete slops. I'm even on one side and 3 and 3 quarters off on one corner. Any suggestions would be greatly appreciated. If I fabricate a piece to go on a door, it will hit my header at the to
mpeak is offline   Reply With Quote
Old 11-28-2010, 02:42 AM   #2
Have you checked the floor for level, as a double check? A 3.75" gap is pretty huge; ;hard to believe the concrete pour was that bad. Is there a way to add a wedge to the end of the door w/ some plates on the inside of the door to help hold it on, and/or screws into the bottom edge of the door itself? What about leveling the floor w/ a wooden or concrete wedge, as gross as that may look? Man, this sounds like a tough one. Good luck. j
The Following User Says Thank You to jklingel For This Useful Post:
mpeak (11-29-2010)
Old 11-28-2010, 07:47 AM   #3
If you have extension springs, you can misadjust one side to be stronger than the other. There are limits to how much this will help, and too much will cause opening/closing problems. The actual solution is to fix the floor. A 2x4 cut to level the opening, glued and secured with tapcons, may help
The Following User Says Thank You to Just Bill For This Useful Post:
mpeak (11-29-2010)
Old 11-28-2010, 12:41 PM   #4
Household Handyman
Seen this a couple of times, but not that bad a slope. The solution to resolving your problem will depend on 1) your skills as a DIY + person, and 2) the material(s) your garage door is made of. If there is a weatherstripping on the bottom of the door-remove it properly to re-use it. Unlock the door from the auto open/close mechanism and lower the door-CAREFULLY-onto a 2x4 laid flat at the middle of the door's width. Then measure the actual opening at both the right and left sides from the bottom of the door to the concrete. You will then have to make a "wedge" to match these dimensions on each end minus the thickness of the 2x4 and the width of the door itself. This could be made in multiple pieces if attached properly. Then you would re-attach the weatherstripping, connect the auto opener/closer and have to re-adjust it for the "closed" setting. That's just a short version of how it's done. I've done two (2) of these, only two, and it takes up quite some time to get it right. And YES-when you open the door all the way it will look as if it is crooked, but you can't have everything. Either a door that seals closed and looks crooked open, or a door that looks good open, but does not seal closed.
The Following User Says Thank You to Thurman For This Useful Post:
mpeak (11-29-2010)
Old 11-28-2010, 02:21 PM   #5
Post a picture with the door closed and one with it open.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
mpeak (11-29-2010)
Old 11-29-2010, 09:30 PM   #6
My door is made out of the foam panels. Im gonna try with a wedge but im afraid it wont work. I think it will hit the header. The reason its off level so bad is i built my garage on my drive way. I put 3 inches of fall in 26 ft. Never thinking about building on it. Thanks for all the suggestions! Ill post pictures when im done.
Old 11-30-2010, 12:02 AM   #7
My door is made out of the foam panels. •• Can't cut the foam to fit?
I put 3 inches of fall in 26 ft. •• 3" in 26' is about 1 3/8" in 12'. How'd you get 3 3/4"? Yah, zap up some pics. This is interesting.
after bullets. j
Old 11-30-2010, 12:24 AM   #8
jlhaslip's Avatar
re-pour the floor???
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
kwikfishron (12-09-2010)
Old 12-08-2010, 10:43 PM   #9
below are attached pictures of the garage project
Garage DOOR WAY OFF DUE TO uneven slope!-1201001646-1-.jpg   Garage DOOR WAY OFF DUE TO uneven slope!-1201001646a-1-.jpg   Garage DOOR WAY OFF DUE TO uneven slope!-1201001647-1-.jpg   Garage DOOR WAY OFF DUE TO uneven slope!-1201001858-1-.jpg   Garage DOOR WAY OFF DUE TO uneven slope!-1208101711-1-.jpg
Old 12-09-2010, 05:51 PM   #10
Household Handyman
That is a lot of slope for that small distance. The suggestion I gave would work in this case without hitting the header above. I did fail to mention in my previous post that the thinner end of the "wedge" should be no less than 1/2" to prevent splitting. As I stated, this has worked for me twice.
Old 12-09-2010, 06:01 PM   #11
Moderator
kwikfishron's Avatar
I’d be barking at the contractor, that’s unacceptable.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 12-09-2010, 06:20 PM   #12
I'm with Thurman. Sounds like a great idea.
SPS-1 is offline   Reply With Quote
Old 12-09-2010, 07:14 PM   #13
Moderator
mpeak, your last picture is as about as good as you’re doing to get other than re-pouring. This is obviously new construction and there is no legitimate reason why this was poured like that.
-NEW MEMBERS-
Old 12-09-2010, 07:32 PM   #14
Concrete & Masonry
I agree with Ron, this is unacceptable.
There has to be more to this story, like the OH door opening was never intended to go there. That's more than a minor screw up.
As a long term solution, I see some concrete beign torn out & poured back in, being blended into the the existing.
jomama45 is offline   Reply With Quote
Old 12-09-2010, 07:36 PM   #15
Moderator
"The reason its off level so bad is i built my garage on my drive way." ---- that's on the side slope of the driveway............
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Garage DOOR WAY OFF DUE TO uneven slope! dogdoc General Discussion 11 07-09-2012 08:23 PM
Garage floor slope. jogr Building & Construction 6 10-09-2010 07:15 AM
Fix Garage Slope acerunner Building & Construction 6 07-13-2010 10:05 PM
Garage Floor slope jogr Building & Construction 3 10-07-2009 11:16 AM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
