Garage Door Track Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 02:39 PM   #1
Rewards Points: 150
garage door track question
I am re-taping and painting my garage ceiling. The rear support bracket for my garage door track is bolted directly to the ceiling joist, with a hole cut in the drywall for access. Bought this house a year ago so don't know the back story. My question, can I unbolt this, patch the hole, and bolt up the bracket on the surface of the drywall. This will move the rear part of track down 5/8". I could adjust the bracket but the holes are 1" apart so that would move the track up 3/8". Will this cause any problems? Can I unbolt this without killing myself? (door down, of course) I know zippy about garage doors. Thanks.
silversport is offline   Reply With Quote
Old 04-21-2012, 03:14 PM   #2
DIY staff
Rewards Points: 7,174
Yep--Unbolt it--add drywall and reattach---you may need to drill a new hole into the track if the door doesn't work properly---but I bet it will be fine without messing with the adjustments.
Old 04-21-2012, 05:01 PM   #3
Also.....
Typical fastener is approx 1 1/2 inches.
Grab some similar size lags but add an extra inch in length.
I've seen plenty pull out of the drywall over the years!
Doorman54 is offline   Reply With Quote
Old 04-21-2012, 05:56 PM   #4
Rewards Points: 150
Thanks for the advice!
Old 04-22-2012, 10:20 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
maybe get a few measurements off of the wall and a few spots on the ceiling that correlate with where the bracket sits now so later after you have the drywall fixed you will know exactly where the bracket goes back.
hand drive is offline   Reply With Quote
Old 04-22-2012, 12:48 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
As noted above...no problem. In fact, with the door down....the rail will hang there nicely without support.....
But I hate those ugly brackets.....this is my solution....
Old 04-22-2012, 04:09 PM   #7
Rewards Points: 150
Thanks again for the replies, especially the tip on the length of the lag screws. I would've slept on that until it was time to re-attach. I used a plumb bob to keep the track located. Going to look much better than it did once taped and finished.
Old 04-22-2012, 07:58 PM   #8
firehawkmph's Avatar
Rewards Points: 1,884
Looks good SS,
one more thing, since you're doing such a nice job cleaning things up. Take a hacksaw or a sawzall if you have one and cut off the couple inches of the vertical angle hanging down below the garage door track.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-22-2012, 08:56 PM   #9
Missouri Bound's Avatar
Nice job. And I know it's after the fact but in similar situation I have used plywood as the patch instead of drywall where the hardware fastens.
Do you want it your way or the right way?
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 12:30 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
