Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-20-2010, 11:43 PM   #1
Garage Door Springs
I think I have a 100# garage door. It is 8' x 8'.
HD has springs rated for 90# or 110#.
Which would you go with for replacement and why?
(Amarr - Traditional Composite) - no specs
http://www.amarr.com/residential/bro...composite.html
handy man88 is offline   Reply With Quote
Old 10-21-2010, 01:40 AM   #2
jlhaslip's Avatar
Garage Door Springs
go with the higher rated ones even if you need to adjust their tension down instead of the lighter ones being cranked over-spec.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 10-21-2010, 04:39 PM   #3
Garage Door Springs
How are these springs adjusted?
Old 10-21-2010, 05:22 PM   #4
uva uvam videndo variafit
WirelessG's Avatar
Garage Door Springs
If you don't know how to adjust them, then you should contact a service company. Those springs can be dangerous when tensioned.
WirelessG is offline   Reply With Quote
Old 10-21-2010, 05:42 PM   #5
jlhaslip's Avatar
Garage Door Springs
Couldn't agree more...
Old 10-21-2010, 07:40 PM   #6
SDC
SDC's Avatar
Garage Door Springs
Different strength springs are color coded. Match the correct color with the color you remove. Extension springs are not adjustable.
The adjustable ones they are talking about, I am guessing, are torsion springs, which are adjustable.
Make sure you install the safety cables in the springs.
http://ddmgaragedoors.com/springs/ga...or-springs.php
The door needs to be balanced, when you open the door half-way, it should stay put, not go up or go down. Then you will know it has the right tension.
SDC is offline   Reply With Quote
The Following User Says Thank You to SDC For This Useful Post:
handy man88 (10-21-2010)
Old 10-21-2010, 07:53 PM   #7
Garage Door Springs
Thanks.
I do have extension springs. I was shocked to hear that they are adjustable, but after your explanation, I know they are not.
Where is the color coding generally found on the spring?
Also, with extension springs, do you think it's better to have less power or more power if there's not a direct load match?
Old 10-22-2010, 01:52 PM   #8
gravity always wins
Garage Door Springs
Extension springs are rated for weight and length of travel. A spring on a 9 foot high door has to stretch farther than a that on a 7 foot high door. Also a 1-3/4" thick door will, of course, weigh more than a 1-3/8" door. The color code is a paint spot at or near the end of the spring. Could be blue, white, red, etc. Get the right color to match your door size and weight.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
handy man88 (10-22-2010)
Old 10-22-2010, 08:18 PM   #9
Garage Door Springs
Extension springs are adjustable to a certain extent; the cable sheave can be lengthened or shortened to help with the door weight and balancing.
Once the springs are taken out of service, place a bathroom scale under the door when down to get the weight. This will help with spring selection. Be careful, the door will come down with great force when no springs are attached; use two people to help it shut with no kids or pets around!
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Old 01-15-2012, 03:02 PM   #10
Garage Door Springs
This is a tough job, this helped alot http://howtofixstuff.blogspot.com/20...or-spring.html
bugmenot is offline   Reply With Quote
Old 01-15-2012, 03:13 PM   #11
Garage Door Springs
I agree!
Don't mess with them, they can get you bad!
Hardway is offline   Reply With Quote
Old 01-16-2012, 11:04 AM   #12
Garage Door Springs
ok...time for a "stupid DIY'er" story.
My first house...many many moons ago, when I was just a lad, I had a garage door spring break. So I bought the replacements and proceeded to attempt to install them. I figured this would be simple enough as I have always been a pretty handy guy. Well...I took off the broken one...no problem. Then I started to take off the other side that was still tensioned. I had NO CLUE what was about to happen.
You all know where I am going with this, but when I put my wrench on the nut....started to loosen it....all I can say is I am VERY LUCKY I was not in front of it and off to the side.
The wrench was sent at about 150 mph to the back of my garage, went through the sheetrock, through the insulation and through the siding.
After realizing I had just about died, I found my wrench in the backyard.
I look back now and really am glad the internet is here now lol.
I did get the new springs installed, and tensioned properly, but only after talking to some people that knew how to do it.
Just wanted to share
lowvolter is offline   Reply With Quote
The Following User Says Thank You to lowvolter For This Useful Post:
mae-ling (01-16-2012)
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
