Garage Door Replacement - Rear Support Bracket Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 06:31 PM   #1
Rewards Points: 14
Question
Garage door replacement - rear support bracket question
Hello,
I planning on replacing my garage door with a new clopay value plus metal door. I read in the installation manual that the door does not come with a rear brackets, but the old door already has brackets that tracks attach too.
My question is do I need to replace them? they are about 60 years old (I think, not sure if they even had garage doors back then ) Appear to be solid. I think they are cold press metal, pretty thick.
pictures attached.
thanks
ipokrov
Garage door replacement - rear support bracket question-left.jpg   Garage door replacement - rear support bracket question-right.jpg
ipokrov is offline   Reply With Quote
Old 12-08-2012, 06:26 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
They look fine from the pictures. Measure between them and as long as they are in the right position, re-use them. Be sure they are properly attached above the ceiling. A steel strap like that will carry a lot of weight.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ipokrov (12-08-2012)
Old 12-08-2012, 07:14 AM   #3
Rewards Points: 13,732
Those look better then what most people use now.
Old 12-08-2012, 11:27 AM   #4
Rewards Points: 14
Thanks, I will check how they are attached above, I assume that they should be attached properly now. they are currently support an old wood door that I think is heavier than new one. I will measure the distance, but I hope sense I replacing with same size door, the new tracks should be close in size to what I have now.
Old 12-08-2012, 11:29 AM   #5
Rewards Points: 14
I think so too. I looked at what HD carries and look flimsy. This is old school rolled steel.
Old 12-08-2012, 01:44 PM   #6
If you have to drill them for an eye bolt to attach the spring, be sure not to drill too much material away.
How to support garage roof -- cutting header for new addition amy6152 Building & Construction 11 03-21-2012 01:36 PM
new member with question on support beam pointer80 Building & Construction 7 02-02-2012 09:23 PM
Rewiring the house, garage subpanel question WillK Electrical 4 09-28-2010 10:14 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
