-   -   Garage door replacement - rear support bracket question (http://www.diychatroom.com/f2/garage-door-replacement-rear-support-bracket-question-165866/)
ipokrov 12-07-2012 06:31 PM
2 Attachment(s)
Hello,
I planning on replacing my garage door with a new clopay value plus metal door. I read in the installation manual that the door does not come with a rear brackets, but the old door already has brackets that tracks attach too.
My question is do I need to replace them? they are about 60 years old (I think, not sure if they even had garage doors back then :) ) Appear to be solid. I think they are cold press metal, pretty thick.
pictures attached.
thanks
ipokrov
Maintenance 6 12-08-2012 06:26 AM
They look fine from the pictures. Measure between them and as long as they are in the right position, re-use them. Be sure they are properly attached above the ceiling. A steel strap like that will carry a lot of weight.
joecaption 12-08-2012 07:14 AM
Those look better then what most people use now.
ipokrov 12-08-2012 11:27 AM
Thanks, I will check how they are attached above, I assume that they should be attached properly now. they are currently support an old wood door that I think is heavier than new one. I will measure the distance, but I hope sense I replacing with same size door, the new tracks should be close in size to what I have now.
ipokrov 12-08-2012 11:29 AM
I think so too. I looked at what HD carries and look flimsy. This is old school rolled steel.
Maintenance 6 12-08-2012 01:44 PM
If you have to drill them for an eye bolt to attach the spring, be sure not to drill too much material away.
