Garage Door Randomly Opens - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 09:56 AM   #1
garage door randomly opens
hello,
my garage door will randomly open. very rarely, but usually at night or during the day when i'm inside. does hitting the "learn' button help here at all?
I can think of 2 possible problems: 1) There might be a remote (i'll call it "lost remote" somewhere witha low battery that might trigger it, 2) a neighbor's remote is activating it
1. would hitting the learn button and using the remote that I have handy make the possible "lost" remove inactive?
2. would hitting the learn button reprogram a code making a neighbor's remote no longer able to active my garage door?
3. any other suggestions?
Thanks!
junkemail0707 is offline   Reply With Quote
Old 02-09-2011, 11:19 AM   #2
Remodeler
Rewards Points: 330
What brand? If it is a sears, chamberlain, liftmaster, master mechanic or Do It Best brand, holding the learn button down for a few seconds erases all the codes, then press and release the learn button to activate learning mode and then press and release the remote button to reprogram it. Make sure the remotes don't have a button that sticks, have had that happen too. One button sticks and when a remote for a different door is activated both doors end up operating. Sometimes cold weather will cause the buttons to stick too.
iamrfixit is offline   Reply With Quote
Old 02-09-2011, 11:20 AM   #3
it's a craftsman (sears). thanks for your reply!
Old 02-09-2011, 11:36 AM   #4
Rewards Points: 120
I would go through the reconfiguration process, as described above, but would first unplug it for a couple of minutes, as it sometimes helps to reset such devices in this manner.
Old 02-09-2011, 11:56 AM   #5
Rewards Points: 38
I had a similar problem, not sure if this will help but here is what i found and my solutions.
1. did an internet search and found several possible causes. 1) interfereance from aircraft with in 50 miles of an airport. 2) shorted push button wires usally from mice. rulled out 2. i am 25 miles from Logan and on a landing approach which is a high traffic area. i could not rule that out.
2. roofers working across street may have had a remote to start compressor. had problem even when they weren't working.
while cleaning chain drive, I noticed a roller had popped out of the channel, upon inspection the roller bearing was gone after 25 years of use. replaced 2 rollers, problem solved. from ground level I never noticed the roller out of the track. when up on the ladder looking across the top of the lift motor I saw it. this put a stress on door, which twisted the lift chain which effected micro switch on motor.
this was over a year ago. over this winter it opened again. not roller this time. chain was stiff from the cold. this torqued the cam away from the micro switch. cleaned and lubed again, no prob since.
hope this is helpful.
bernie
bernie963 is offline   Reply With Quote
Old 02-09-2011, 04:58 PM   #6
I had a Craftsman in my previous house and had the same problem but it wasn't during cold weather or because of a lost remote. We ended up having to reprogram it and that fixed it. I would try that if you haven't already. Coming home to your garage wide open is very unnerving, so I hope you can get it fixed soon!
MsMatthews is offline   Reply With Quote
Old 02-13-2011, 02:43 PM   #7
How old is the unit? A lot of the older craftsman model were on the same frequency as stated in am earlier post, some aircraft.
Tomperro is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage door opens by itself n0c7 General DIY Discussions 6 03-17-2009 10:33 AM
