Garage Door Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-10-2006, 10:38 PM   #1
i'm Going To Install A Garage Door Motor For A Dumb Waiter,what I Need To Know Is What Is The Distance Of Travel Can I Get By Setting The Up And Down Switches To The Max.the Dumbwaiter Will Be Going About Ten Feet.
JOAT is offline   Reply With Quote
Old 04-11-2006, 07:39 PM   #2
What type of opener? chain or worm?
didn'tdoit is offline   Reply With Quote
Old 04-11-2006, 10:20 PM   #3
Chain Drive
Old 04-11-2006, 10:44 PM   #4
I guess my question is what length are you needing and what is the bar length, as long as it is long enough you should be ok with the switch adjustment.
Old 04-12-2006, 10:36 PM   #5
Chain Length Is No Problem
I Can Make The Chain Long As I Want.will Be Using Chain And Sprocket Only.nothing Else Will Be Needed,with The Exception Of The Motor Mounting Brackets.if I Were To Bypass The Switches The Motor Should Continually Run In One Direction Until The Power Is Interrupted.then When It's Powered Again It Should Run In The Other Direction.i Don't Have A Motor To Experiment With But I'm Pretty Sure That's What Would Happen.
New Heated Garage: need help! HardcoreCBR General DIY Discussions 12 05-23-2008 08:34 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
