Garage Door Opening Problem. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 10:36 PM   #1
Garage Door opening problem.
Need some advice/help/info please.
My home is 6 yrs old, with a 16 x 7, 5 section steel garage door, and a 1/3 hp AccessMaster chain drive opener. Several days ago, it started having problems opening. It would rise up about a 1/3 or 1/2 of the way up, then stop. After a few tries, it would finally open all the way. It seemed to be intermittent at first, but now it's happening all the time and getting worse. After spending a major part of yesterday greasing all the joints, rollers, springs and chain, nothing seemed to help. Today I took the opener apart and found nothing broken or stripped, no plastic or metal shavings anywhere. When the door is disconnected from the carriage, it's opens easily without any hangups. Same goes for the opener when it's disconnected from the door, it will cycle through without issues. I've tried adjusting the settings, unplugging and resetting it, and everything else I can think of. ARGH...
Long story short, is it just time for a new opener?
Any advice is appreciated!
SwooshDaddy is offline   Reply With Quote
Old 10-29-2010, 12:52 AM   #2
Does the light on the opener flash when it stops? Are the safety sensors operational?
Shane1 is offline   Reply With Quote
Old 10-29-2010, 01:10 AM   #3
Not sure about the light, I've never had a bulb in there.
The sensors are operational, and work fine when the door closes.
It's upon opening, that is the problem...
Old 10-29-2010, 07:51 PM   #4
Household Handyman
Rewards Points: 1,408
Been here, seen this. You probably opened the door manually like most people would do: by raising it from the bottom, sort of pushing it up. That's not the way your auto opener works. It pulls. BE VERY CAREFUL if you do this, actually have some help: Try standing on a small/short ladder and pulling the door open as the auto opener would work. I've done this many times and found doors which would hang up this way when pushing them up would work just fine. I'm also not a fan of lubing the tracks the door moves in. I do clean them out, but do not lube them. Any lubricant is just something to hold dust/dirt in place to me. I do/have applied a drop or two of oil to the rollers in the wheels. On units with the round rod type guide I like to clean them with a fine emery cloth, then wipe them with a rag with a few drops of oil.
Old 10-29-2010, 08:27 PM   #5
Thanks for the response, but I've tried opening the door by both pushing and pulling. I thought about the same thing you said, so I tried simulating the opener by pulling the carriage. I parked my truck under the track and walked along while pulling, and everything still went smoothly, just as when I pushed from the bottom. No hangups anywhere. The opener was pulling the door about halfway up, then a third, and now it's getting 6 inches or maybe a foot before stopping. Anything else I could try before replacing the opener?
Old 10-29-2010, 08:31 PM   #6
jlhaslip's Avatar
Rewards Points: 396
How much (if any) play is in the wheels?
Has the track been moved and pinching the rollers stops them from working?
Are there adjustments on the opener for Force?
Unless you are familiar with garage doors, I would consult a local installer for adjustments required.
1/3 HP seems light for a 16ft door.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-30-2010, 12:53 AM   #7
There isn't any play in the wheels, everything there is solid.
Tracks and rollers haven't been touched except for what I've done the past few days.
I've tried making force adjustments, but mothing changed.
My neighbor has worked with garage doors in the past, and didn't see anything out of the ordinary.
He is guessing it's the motor going bad and suggests replacing the opener.
Old 10-30-2010, 01:16 AM   #8
jlhaslip's Avatar
Rewards Points: 396
Best check for that is to disconnect the opener to see if it will go up/down.
Try a 1/2 HP next time and confirm there are enough turns on the spring.
Old 10-30-2010, 02:55 PM   #9
firehawkmph's Avatar
Rewards Points: 1,800
Sounds like the door itself is operating properly. If you have turned the opening force adjustment up all the way and it still acts up, then replace the opener. Try and get an opener through a local garage door company. They sell genies and liftmasters with one piece tracks, not like the openers in the big box stores that have multiple piece tracks. I normally hang liftmasters now after hanging genie promax's for years. I like the LM better. 1/2hp chain drive is a good unit. 3/4hp belt drive in the elite series is top of the line, very quiet.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-30-2010, 09:41 PM   #10
Hey Mike, thanks for the help! I bought a new opener, and got the Liftmaster belt drive. You weren't kidding, that thing is almost silent!
Very happy with it, and thanks for the recommendation. The install was easy, and solved all my problems with the door.
Old 11-02-2010, 05:29 PM   #11
Good to hear SD
Mike Hawkins
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 04:01 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Garage Door Remote Problem pgr380 Electrical 2 11-21-2009 11:23 AM
Problem with garage door side entry thundercloud Carpentry 6 06-09-2009 07:27 AM
Strange Garage Door Opener Problem mnewmanfla General DIY Discussions 6 03-20-2009 07:36 AM
