Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-03-2011, 06:48 PM   #1
a garage door opener is strong
painted the house and garage door....paint dried and two days later went to open the garage door.....door was ''painted shut'' and garage door opener's rails? buckled trying to open.....what is the proper name for those ''rails'' that the carriage rides on ?????
saltysenior is offline   Reply With Quote
The Following User Says Thank You to saltysenior For This Useful Post:
gregzoll (02-03-2011)
Old 02-03-2011, 07:14 PM   #2
nap
You talking to me?
nap's Avatar
I generally hear it referred to as "track"
just to be clear;
you are talking about the track or rails that are on either side of the door, right?
Old 02-03-2011, 07:21 PM   #3
no...i'm talking about the 2 rails that carriage[on the chain] slides back and forth on...
Old 02-03-2011, 08:07 PM   #4
nap
You talking to me?
nap's Avatar
there are a few different types of openers but from what I can find, "rail" seems to be the most common term used.
Old 02-03-2011, 08:55 PM   #5
Experienced
Jackofall1's Avatar
I'd say your torque settings were a wee bit high on that openner.
Sounds like it was set to crush cars and trucks.......
Mark
Old 02-03-2011, 09:01 PM   #6
Mark
Yeah that was my thought also. It should have aborted before in bent the rails. That much opening force could accidentally hang a child playing too close to the door. Closing, it could crush a child.
Jim F is offline   Reply With Quote
Old 02-03-2011, 09:38 PM   #7
nap
You talking to me?
nap's Avatar
Not if it has a door bottom sensor or beam sensor.
I think they are now requirements but not sure. Anyway, you should have one of them whether it is a requirement or not.
Old 02-03-2011, 09:49 PM   #8
the sensor worked on the lowering cycle....got dents in everything...but i don't know if it works on the raising cycle...i watched it twist the rails,and then gave an angry hum when they would not bend anymore.....but now i have to find out how to replace them...
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
