Garage Door Opener Problems - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-21-2011, 03:58 PM   #1
Rewards Points: 31
garage door opener problems
i have an 18 year old quarter horsepower sears craftsman chain driven garage door opener lifting a single width door. the door opens fine. recently the door has not been going down . it will go part way down then return to fully open. i have greased and tightened the chains and rails. and have attempted to adjust the up and down force screws in many different combinations with no luck. i have another door with the identical set up which works fine and have even tried switching the springs from that good door to the bad one with no change.when i release the door from the opener and manually raise and lower the door it seems to move fine. the safety sensors at the bottom of the door seem to be ok as i dont see them flash when the door returns to open,any ideas? if i have to buy a new opener and install it i have no problem with that,,,,maybe its had its time. thanks paul
pberm1962 is offline   Reply With Quote
Old 11-21-2011, 05:19 PM   #2
Hell of a fella
Rewards Points: 27
Could the sensors just need cleaned? Maybe some sawdust and other usual garage dirt may have messed with them. Or maybe the sensors just need replaced.
DrumBum is offline   Reply With Quote
Old 11-21-2011, 05:31 PM   #3
Rewards Points: 31
sensors
the sensors due not appear to be failing, the solid green light is on both sensors, if i pass my hand in front of the beam the light goes off as it should.. when the doors stops in mid flight on the way down the sensor leds stay solid like nothing is passing in front of them,,, could they still be failing if the leds arent going off in mid travel?
Old 11-22-2011, 07:42 AM   #4
Check door operation manually with the opener disconnected. It should go up/down easily with not binds/catches. You should be able to stop the door mid travel and it will stay when you let go. If that all works, you need a slight adjustment to down force.
Old 11-22-2011, 08:01 AM   #5
Rewards Points: 5,336
I'd try switching sensors with the other door. Just because the LED's stay on, doesn't mean it necessarily rules them out as the problem.
Ron
B. Franklin 1759
Old 11-22-2011, 11:58 AM   #6
Rewards Points: 31
manual operation
when i operate the door manually it will go down no matter what position i start it in, i can raise and lower it smoothly but it wont stay in any one position,,,are the springs weak?
Old 11-22-2011, 03:32 PM   #7
They could be just be adjusted incorrectly. It's the springs that actually do the work in raising and lowering the door. The opener just guides it. It puts more stress on the opener if the springs are either incorrectly adjusted or the wrong size altogether.
This won't effect your other stopping issue.
Ron
B. Franklin 1759
Old 11-22-2011, 07:01 PM   #8
Rewards Points: 31
adjusting springs
if the springs are not adjusted properly can i do the adjusting and if so how is it done? i know and respect the power in the springs and would only attempt something when the door is up and there is slack in the springs....and then stand back.
Old 11-22-2011, 09:02 PM   #9
firehawkmph's Avatar
Rewards Points: 1,822
Paul,
Do yourself a favor and go get a new opener. If you got 18 years out of a 1/4hp sears (liftmaster), you did good. The new ones don't usually last that long. I replace a lot of sears openers that are under 10 years old. Liftmaster still makes them, but to Sears' specs. If you aren't versed on garage door repairs, best to find a local independent garage door repairman. It's a simple job for him to check and adjust your door to make sure its working properly and also can check your opener while he's there.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-23-2011, 08:54 PM   #10
18 Years
If you already got 18 years of service from that old garage opener, consider yourself very lucky. I think it's time for a new one.
jorgea is offline   Reply With Quote
Old 11-23-2011, 11:17 PM   #11
Rewards Points: 31
agreed
sorry i started a new post asking about a belt drive (quieter) unit which i am gonna go with,, you are right i am blessed getting that much use outta that opener and i cant believe how fast time flies
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 04:01 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 06:38 PM
